Using RH9. We created a number of To Do List entries for one of our Robohelp projects that we now want to use in all of our RH projects (File > Project Settings > Manage To Do List for Robohelp Project). Is it possible to copy these entries from one project to another? Or do we need to re-create the list of To Do tasks for each one of our 20+ projects?
Hi there
The "To Do" list items appear to be stored directly in the ProjectName.XPJ file. So theoretically it would be possible to copy them by opening one XPJ using Windows Notepad, copying them, then opening the target XPJ and pasting. However, this will likely cause a disparity between the XPJ and the .CPD. So before actually opening the project where you are copying them into, you would want to close the project and delete the CPD. Then modify the XPJ and re-open the project. A fresh CPD shou
...Copy link to clipboard
If you can identify which file it is, you can probably copy it from project to project without harm (always do a test on a blank project). I do that with a customized RoboHHRE.lng file where I've played with the wording for the navigation text.
Hi there
The "To Do" list items appear to be stored directly in the ProjectName.XPJ file. So theoretically it would be possible to copy them by opening one XPJ using Windows Notepad, copying them, then opening the target XPJ and pasting. However, this will likely cause a disparity between the XPJ and the .CPD. So before actually opening the project where you are copying them into, you would want to close the project and delete the CPD. Then modify the XPJ and re-open the project. A fresh CPD should then be baked up and things should be in sync.
You might also want to submit a Wish Form to ask for an easier way to transfer custom lists. (link is always in my sig)
Cheers... Rick
Thanks so much! You guys are awesome as usual. Copying the TODo section of the XPJ worked like a charm and wasn't hard to do. I also submitted a Wish Form to Adobe.
Here's exactly what you need to do for future reference:
