4 Replies Latest reply on May 11, 2012 3:51 PM by areohbee
    LrUUID
    areohbee Level 5
      I've been using the undocumented LrUUID namespace for a while now without any problems, however I just had a user report the error:
      Could not find namespace: LrUUID
      He's using Lr3.4 on Vista
      Anybody know in which version of Lightroom this namespace first appeared?
      I can't imagine it being an OS thing(?)
      Rob
        • 1. Re: LrUUID
          johnrellis Most Valuable Participant
          The perils of using undocumented interfaces (of which I'm equally guilty :-<).
          Seems unlikely that this would be dependent on the Windows version (i.e. not available in Vista).  The result of LrUUID (on Windows 7) looks like a Windows GUID:
          "C57FA964-8A58-4195-9A76-B6002A9633AC"
          Windows GUIDs have been around since at least Windows NT 3.5, I think, when Microsoft collaborated on the DCE standard.
          • 2. Re: LrUUID
            areohbee Level 5
            Thanks John,
            User is upgrading to Lr3.6 now, I'll let you know if it makes a difference.
            Rob
            • 3. Re: LrUUID
              Matt Dawson Level 3
              It does seem like an odd error to experience. Namespaces aren't typically
              something that would change across OSes or even within a major release
              cycle. Would have expected that namespace to have been available since at
              least LR3.2 (but more likely LR3.0) so the upgrade shouldn't really be
              necessary. Lets hope the upgrade fixes the problem for your user.
              Thanks, Matt
              (Apologies for the brevity - sent from my Android)
              • 4. Re: LrUUID
                areohbee Level 5
                My solution:
                math.randomseed( LrDate.currentTime() ) -- moved from app constructor.
                local lrUuid = import 'LrUUID'
                if lrUuid ~= nil and lrUuid.generateUUID ~= nil and type( lrUuid.generateUUID ) == 'function' then
                    -- good to go
                else
                    -- Note: Lightroom uses HEX instead of Base-10, but that's a way to distinguish a "REAL" UUID from one of these PSEUDO UUIDs.
                    lrUuid = { generateUUID = function()
                        local n1, n2, n3, n4, n5, n6
                        n1 = math.random( 10000000, 99999999 ) -- 8-digit random num
                        n2 = math.random( 1000, 9999 ) -- 4-digit random num
                        n3 = math.random( 1000, 9999 ) -- 4-digit random num
                        n4 = math.random( 1000, 9999 ) -- 4-digit random num
                        n5 = math.random( 100000, 999999 ) -- 12-digit random num
                        n6 = math.random( 000000, 999999 ) -- part 2.
                        local pseudoUuid = string.format( "%8u-%4u-%4u-%4u-%6u%06u", n1, n2, n3, n4, n5, n6 )
                        return pseudoUuid
                    end }
                end
                gbl:initVar( 'LrUUID', lrUuid, reloading ) -- not documented @LR3
