1. Re: What is `ideas` for?
David__B Feb 9, 2012 2:58 PM (in response to bgp_1984)Hi bgp_1984,
Adobe Ideas is an app for sketching or drawing on the top of an imported image. The Android version is different than the iOS version in relation to the number of layers available . The Android version currently only supports a background layer and a single drawing layer. Because the app works with vector rather than pixel data it allows you to import your drawings into Illustrator rather than Photoshop. See this document for more info:
http://forums.adobe.com/docs/DOC-1337
If you work with layers a lot a better app for you might be Photoshop Touch. I'll email you directly to see if I help you work things out.
-Dave
2. Re: What is `ideas` for?
Takashi Morifusa Feb 13, 2012 10:31 AM (in response to David__B)Hi bgp_1984,
You can download plugin for Adobe Illustrator CS5.0 or CS5.1
https://creative.adobe.com/downloads
You can open Adobe Ideas file into Illustrator. you can modify the vector artwork and also you can export as jpeg or save as .ai file and bring it Photoshop CS5.x as smart object.
Takashi
