I'm using Windows 7 Platform. I use Mozilla and Internet Explorer 9, with both browsers I run into the same problem.
I try to download Flash Player 11 and I get this error message::
C:\Windows\system32\DSOUND.dll is either not designed to run on Windows or it contains an error.
Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
The download reaches 100% but doesnt work on either of the browsers due to the error message. So far I've uninstalled reinstalled browsers and Flash Player 11 numerous times direct link and indirect links. I've toggled the activex options for the Scripts but the error message still pops up.
This is a 32 & 64 bit Flashplayer.
I NEED HELP PLEASE!!!!!
You can download Adobe Flash Player 11 from here :
32-bit Windows:
Flash Player for IE : http://fpdownload.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_player_11_activ...
Flash Player for other browser : http://fpdownload.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_player_11_plugi...
64-bit Windows
Make sure you save the file and run it.
Note : Your browser should be closed while installing Adobe Flash Player 11
Hope it helps.
Vikram
I still get the same error message
DSOUND.dll is a system file.
Click start, type cmd, right click cmd and run as administrator.
Type sfc /scannow and press enter.
Results from cmd:
Verification 100% Complete.
Windows Resource Protection found corrupt files but was unable to fix some of them
Details are included in the CBS.log windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log
Now what ?
I suggest that you head over to Microsoft Answers, tell them that the System File Checker failed to repair some files.
http://answers.microsoft.com/en-us/windows/forum/windows_7-system?tab=all
The sfc results pretty much found my dsound.dll corrupted
In that case can you delete (or rename) dsound.dll and run the System File Checker again?
