Was getting script errors trying to download latest flash. Turned off Norton with right click on yellow task bar, unistalled old flash with the adobe uninstaller...all no help. Then on a hunch tryed Java Test to see if it was working, and it told me I had an older version of java. Once I updated java, then the script errors went away and flash installed properly. FYI.
Hi biff44a,
Thanks for the heads up!
Chris
What is Java Test that you tried? I get script errors when trying to install Flash Player.
Java test: http://www.java.com/en/download/installed.jsp
What are the script errors you are getting?
