I cannot export to pdf from Indesign... I export and then nothing happens. Can someone please help?
Feb 10, 2012 Feb 10, 2012
Indesign worked well for a long time.  Then recently, after I and to reset my computer to an earlier time, Indesign stopped letting me export to PDF. I get no error message.  It is just that nothing happens after I export it.  I have some major deadlines for printin and am desperate for help.  I emailed the Indesign file to someone else and they were able to export it and create a PDF.
I look forward to any suggestions. I would gladly pay someone if they can get it to work again.
26.2K
Community Expert , Feb 11, 2012 Feb 11, 2012
Sure, if you want to pay, they'll be happy to take your money. Call Tech support and open a case. Make sure you get a case number, and the name of the person helping you, and don't let them tell you they'll call you back. If necessary, don't be shy about insisting on being escalated to the next level.
Before you spend money, though, read this thread: http://forums.adobe.com/message/2850080#2850080
It's 4 pages, but make sure you read the whole thing. There are several possible solutions for turnin
Try resetting the prefs as the first step. See Replace Your Preferences
If that doesn't work, you probably need to reinstall.
Peter,
Thanks for the tip.  Seems logical.  I tried it.
However, no luck.
I have reinstalled the program.
Other ideas.
Do you have the latest patch for your version?  Which version are you using, by the way?
Guest
Possibly an Acrobat issue?
Acrobat is not involved at all with an export.
Bob
Guest
Its just ... that Peter said "It is just that nothing happens after I export it." ... When I feel there is a lack of information... I can only assume.
*Grins*
lil
Advisor ,
You mentioned:  ..... to reset my computer to an earlier time
I think it would be helpful for people in the forum if you could clarify how and why you were resetting your computer to an earlier time.
This probably has something to do with the problem you are experiencing now.
Also tell us the version of your operating system and also the version of your InDesign
I have CS5.5.
I reinstalled both the original CS5 and the upgrade to CS5.5.
Here is how my computer technical partner explained what happened...
First the computer was restored to an earlier point, prior to having the problems of locking up, using Windows' system restore. That somehow messed up the user profile and that I had to rebuild. Saved the user's files, deleted and then re-created the user. I've moved all the files that I could without causing the problem to re-occur. The user's registry and the user's application data folder unfortunately contained corrupt files that made that user profile unusable so they had to be omitted but they are all saved on the hard drive in case they need to be accessed.
Since I reinstalled cs5.5 I get an error message "1 Problem (1 failure) was found with a background task: Export:"(filename).pdf" (1)
I took a little while to get a precise answer.  I appreciate the thoughtful questions.
Have you reinstalled the 7.5.2 patch?
No, how do I do that?
Help > Updates...
I found and tried to install the patch.  It said that the install was not successful.
Did the error message say why? Perhaps you tried to install the patch for ID Server..
The help menu path is the best method, if it works.
Peter,
You were correct.  I tried to install the ID server version.
The other version installed perfectly.  That is the good news.
The bad news is that I still get the error  when I attempt to export - "1 Problem (1 failure) was found with a background task: Export:"(filename).pdf" (1)"
Thanks for your ideas. They are important steps to take to eliminate the obvious.
Any other suggestions for next steps?
Is there a tech service at Adobe I can pay for to dig into this?  I need to solve it quickly.
Thoughts welcome.
It's 4 pages, but make sure you read the whole thing. There are several possible solutions for turning off background exports, and some other useful info.
Peter,
Thanks for hanging in there with me.  I read through the four pages and found that if I added the files to a book - then printed the book to a pdf it created a  pdf file.
Many, many thanks.
Peter
Feb 12, 2012 Feb 12, 2012
@ (peterfrommaine)-peter – since you use InDesign CS5.5, be aware that there is a bug (at least up to version 7.5.2) with PDF export with books that could mess up your page numbers. You are not affected, because you printed to PDF (that is the "print-PostScript-distill-to-PDF" way).
But if you want to export to PDF, read this thread:
http://forums.adobe.com/message/3750835#3750835
So then I would go a different route. Use a script that exports in foreground (there are several around; if you read the thread mentioned by the other Peter, you already found that link: ExportPDF_in_Foreground_CS5.jsx) or use the more radical method Matthew Lawn suggested to prevent all background exporting (not only PDF export):
http://forums.adobe.com/message/3689090#3689090
And see the following implementation (very cool) by Marijan Tomba "controlBackgroundExport.jsx":
http://forums.adobe.com/message/3690507#3690507
Uwe
Uwe,
Thanks for these additional thoughts.  I am a new and fairly low tech user of InDesign.  I am using it primarily to edit documents created by others.
My main objective is simply to be able to export files for printing -sometimes I need a single page layout and sometime I need a double page spread layout (for brochures).
I would like to be able to use the full export capabilities again.
Which of the solutions you provided would both:
1) Be easiest to implement?
2) Work well and have little or no side effects?
Finally, would you be so kind as to provide a novice a step by step guide as to how to implement the solution you recommmend?
Thanks for your support.
All the best,
Peter
@(peterfrommaine)-Peter – to prevent export without background functionality you need "controlBackgroundExport.jsx" by Marijan Tomba.
Just read about it here:
http://indesignsecrets.com/how-to-install-scripts-in-indesign.php
If you are on Windows7 the following blog post is a good read:
http://indesignsecrets.com/getting-around-windows-7-security-to-save-files-into-indesigns-applicatio...
Running a script is easy: just locate your script in the Scripts palette of InDesign and double-click on it.
A prerequisite for my script is an already opened InDesign file, just double-click it, choose an output folder, click "open", you will be prompted for a file name, click "ok", the PDF export dialog will pop up and you can go on with exporting to PDF as you are used to it…
Note: you can apply a keyboard shortcut to the script.
Uwe
Uwe
Jan 25, 2022 Jan 25, 2022
This is all very helpful, so thank you very much! But, run a script...? Seriously Adobe? I admit my ignorance, but still, is this too much to ask for:    " File    >    Export "
This is ridiculous. I know if I loved sitting in a chair for years and getting into the weeds with ID I would find it amazing, but let me just say the future is bright as far as userability for this kind of software goes. I have never had so much trouble formatting via human logic -- and yes, that includes Word and all the MS stuff.
Anyway thanks again, I guess I'm gonna try and hack into the mainframe in order to receive my cutting edge, top-of-the-line, state-of-the-art PDF!
Jan 26, 2022 Jan 26, 2022
Hi @Nick22831692c1xd , I think you missed that this thread is ten years old. If you’re having problems exporting to PDF, maybe start a new thread, or let us know the details of your problem along with your InDesign version and OS info
Aug 13, 2013 Aug 13, 2013
We just experienced the same ERROR! and I read this forum from top to bottom.
The answer was plane and simple.
The folder I was trying to EXPORT the PDF to was a Read Only Folder created on our LAN network by my collegue.
So CHECK YOUR FOLDER PERMISSIONS or simply SAVE/EXPORT the PDF to you desktop.
Worked like a charm!
Sep 04, 2014 Sep 04, 2014
Paul, You win the genius award and saved my bacon! Thanks... simple as a stupid folder permissions issue. Worked immediately. You're the best.
Nov 30, 2014 Nov 30, 2014
just noticed this message (not active in the Forum world) except for reading…glad I could of been assistance.
