I need to change the names of a couple of projects. I went to File > Rename Project, and changed one of their names. I selected the new name to display in the header, and told Robohelp to create a new directory with the new name.
As I'm looking in the project, I noticed that the names of the Default Index and the Default TOC have not changed.
Where do I go to change these?
I had to think about it for a minute because Peter doesn't indicate what specifically I should right click. I didn't want to do it in Windows Explore at the file level, which was what I presumed he meant. I found it, for anyone coming along later. You go to Project Manager and expand the Index folder, then right click the Index default file name. Same with the TOC.
Thank you, Peter.
Right click them and select Rename.
Thank you, Peter.
Apologies for the half answer. I rattled it off in the middle of doing something else and omitted the obviously needed bit of information.
