1. Re: "Lightroom 64-bit has stopped working"
DavePinMinn Jun 15, 2010 6:56 AM (in response to DavePinMinn)Already answered somewhere else? Known bug? Not interesting?
2. Re: "Lightroom 64-bit has stopped working"
frizzysky Jun 15, 2010 7:41 AM (in response to DavePinMinn)I don't have an answer, but I'm encountering a similar thing.
I've had LR2 and have been using the beta LR 3.
Just purchased LR3 this morning and after downloading it, my machine (running Windows 7 on a PC) won't launch it.
3. Re: "Lightroom 64-bit has stopped working"
+becsJun 15, 2010 1:00 PM (in response to frizzysky)
Try deleting your preferences, located at Users/[username]/AppData/Roaming/Adobe/Lightroom/Preferences in Win 7. The preferences file is named "Lightroom 3 Preferences.agprefs". If you have the beta prefs there (named "Lightroom 3 Beta Preferences.agprefs"), delete those as well. Then restart Lightroom.
Another thing to check is whether you have any plugins installed. If so, try removing them (or moving them to a different location temporarily) to make sure none of them are interfering with LR3 startup.
4. Re: "Lightroom 64-bit has stopped working"
DavePinMinn Jun 15, 2010 4:12 PM (in response to +becs)Ick! I JUST got my preferences set up again!
I don't have any beta preferences, and I haven't loaded any plugins.
BUT, just for giggles I'll delete my preferences and redo them...
Interestingly, yesterday, right after I posted the two crashes LR went crazy and did the same
thing 3 times in an many minutes......
I've been using it consistently since then (I'm editing and organizing a ton of stuff for the website) and it
hasn't hiccuped since then....... Bizarre! Cosmic rays? Humidity? Low pressure? High pressure?
Problem is, I KNOW it's gonna zap me again at some critical moment!
5. Re: "Lightroom 64-bit has stopped working"
M Behrens Jun 15, 2010 4:51 PM (in response to DavePinMinn)I've been getting Win7 Pro 64-bit i7 Craches as well. Like you said, I will be developing doing nothing out of the ordinary and it will lockup or crash. Restarting will sometimes crash again very quickly. Then things will be OK for quite a while. Very odd behavior and very difficult to isolate to a set of actions.
I'll try the preferences delete thing, but this seems like a grasp at straws.
I had some issues in Beta 2 that I could isolate to specific actions. This is the same result, just more erratic.
6. Re: "Lightroom 64-bit has stopped working"
M Behrens Jun 15, 2010 5:57 PM (in response to M Behrens)Generated a new preferences file and ther is no resolution. It may be worse now.
Pretty sure Adobe will have this on their radar - but LR3 is unusable for Win7 6-bit Users.
If there are Win7 Pro 64-bit uasers that are having good luck with LR3 and actually developing RAW files - not just scrolling through the library. Please let us know your sysyem specs, maybe we'll see a pattern.
FWIW, I'm working with Canon G10 and 50D RAW files.
7. Re: "Lightroom 64-bit has stopped working"
Stephen_Christy Jun 16, 2010 2:19 AM (in response to M Behrens)For what it's worth, I'm using Lightroom 64 bit on a Toshiba X500 laptop running Windows 7 home premium 64 bit with no problems at all.
Intel Core i7 cpu with 8GB of RAM.
Pretty small catalogue (compared to most, no doubt) - 5,700 images (no video files)
I've not had the problems others have reported with things like slowness in the spot removal tool.
(In passing, most impressed with LR3 - particularly the new process version - and the huge amount of work that's clearly gone into it.)
Stephen
8. Re: "Lightroom 64-bit has stopped working"
M Behrens Jun 16, 2010 7:13 AM (in response to Stephen_Christy)How many of the folks having issues are on dual monitors, utilizing Monitor 1 & 2 in LR?
I was processing a batch of images and was going through the first pass rotating the sideways images (yes, I have my Canon G10 set to not auto-rotate). I found that in the Library module with Monitor 2 enabled the images would rotate ~60 deg of the 90 deg and stop, I would have to click on the next image or anywhere on screen for it to complete. With Monitor 2 disabled the images would rotate completely each time.
My normal usage of Monitor 2 is to have the Grid turned on and use it as a lightbox for navigating the library.
My issues with the Beta 2 release were related to Monitor 2 as well.
I'll be disabling Monitor 2 and we'll see if that resolves the constant crashing.
9. Re: "Lightroom 64-bit has stopped working"
Hobotor Jun 16, 2010 7:40 AM (in response to M Behrens)No issues whatsoever with LR3 here. Agreed, it seems little bit less snappy than 2.7, but I'll just blame that on the heavier algorythms used to improve image quality.
I have roughly twentythousand raw files in my catalog right now.
Using intel e5200 @2.5 ghz
8gb ram
win7 64 bit.
I do keep a clean system though. I did a clean install of win7 and deleted the previews of my LR2.7 installation. Simply updated the 2.7 catalog. -
10. Re: "Lightroom 64-bit has stopped working"
Graham in NC Jun 16, 2010 8:04 AM (in response to M Behrens)No problems on Win7 64, E8400, 8GB, Nvidia 8600GT driver 257.21, dual monitors, intuos 3 driver 6.1.2-4.
100GB cache on seperate drive. I didn't use v2, but I've had no problems at all with the beta or retail versions of LR3. I have near instant scrolling of the catalog (7,000+ images), no lag in development. I will note there was an initial time delay for the computer to build the previews for the catalog, but that's a one-time deal.
Graham
11. Re: "Lightroom 64-bit has stopped working"
DavePinMinn Jul 12, 2010 5:47 AM (in response to Graham in NC)STILL getting the intermittent "Lightroom 64-bit has stopped working" popup. Typically happens in Develop, but I"m not sure that means much since I spend most of my time in Develop. It was old after the second time. It's not REALLY old after the 6th or 7th.....
No data, no reason, no diagnostics. Just a popup that tells me Lightroom is going to close......
Catalog is brand new (had to recreate THAT because of the full-blown crashes that apparently corrupted the old one).
System has multiple spindles with all the Lightroom bits on different ones - cache on one, application on another, images on a third, catalog on a fourth...
12. Re: "Lightroom 64-bit has stopped working"
stanley.holmes@twc.com Jul 21, 2010 1:25 PM (in response to DavePinMinn)I had lightroom3 64bit running with no problems. I noticed that my wacom graphire was not functioning. I downloaded and enabled the new driver from wacom
's web site. I then got the subject error message. I also got this message in photoshop cs4. I uninstalled the program wacom tablet from control panel add remove programs and now both applications seem to be working. I believe that there is a compatablity issue with win7 64bit, photoshop 64bit and lightroom 64bit.
I hope someone finds this information relevant.
13. Re: "Lightroom 64-bit has stopped working"
FasterElectron Jul 21, 2010 2:49 PM (in response to DavePinMinn)Just for info, I am trying out the trial version of LR3 on my Windows Ultimate 64-bit machine with 12G of RAM, dual displays. No problems so far really, but only used the Library function so far; (new to the program so don't know anything about the other 'developing' functions). Anyway, the only odd behaviour I have noitced is that it takes two clicks to maximise the LR desktop on my dual-screen system, i.e. first click maximises the LR desktop but it doesn't actually fill the screen, so 2nd click then makes it fill the screen. Cheers.
14. Re: "Lightroom 64-bit has stopped working"
FasterElectron Jul 21, 2010 5:20 PM (in response to DavePinMinn)Here is another consideration, completely out of left field which just came to mind. I have automatic backups going 24/7 using a NAS on my network. I know that sometimes this backup drive interferes with applications because obviously, if it is acessing a file, (has a file open), to copy ot the backup drive, this file is not available to another application. I have set my NAS up to not backup any system and application files for this very reason, and, I only backup my data files. Hpowever, this can still cause a problem at a particular instant in time with an application trying to get the data file open at the same time the NAS may be saving it. This may be the cause of intermittent program failures, if you run a NAS on your system. Just a thought. Bye.
15. Re: "Lightroom 64-bit has stopped working"
Graham in NC Jul 21, 2010 5:33 PM (in response to FasterElectron)FasterElectron wrote:
This video from Adobe TV should get you up to speed. http://tv.adobe.com/watch/learn-lightroom-3/create-stunning-images-/
Graham
16. Re: "Lightroom 64-bit has stopped working"
FasterElectron Jul 21, 2010 5:37 PM (in response to FasterElectron)And I just thought of even another possibility: On my machine I have some new "green" hard drives, (I think they are Western Digital's). These drives 'go to sleep' after a while of inactivity, (to save power). I notice that when trying to access some data from WORD or EXCEL for example, when the drive has gone into sleep mode, it takes up to about 6 to 8 seconds before my data will load. After that, while I am working, there is no delay in loading or saving. So here again an application may stall because it times out waiting for a drive to spin up and supply data???. Just a thought. Bye.
17. Re: "Lightroom 64-bit has stopped working"
lux studio Dec 7, 2011 10:19 AM (in response to DavePinMinn)Yesterday, I was processing some work on LR3 (Windows 7; LR3: version 3.5) and suddenly a message appears that basically noted windows was closing the application; no known fix available. I tried a second time, same results. So, I spent hours checking out the machine; no identified problems. Back to LR3. I uninstalled and re-installed; however, this second time I only updated to 3.4, not the current one 3.5. So far things appear to be working.
I continue to process my RAW files, moving back and forth to CS5(all plug-ins are located in this program).
Still not certain why LR3 crashed so suddenly.
Guess I'm not alone with this issue.
18. Re: "Lightroom 64-bit has stopped working"
Dave Quail Dec 8, 2011 6:06 AM (in response to DavePinMinn)Win7 64-bit with Lr 3.5 working fine...processing, cataloging, etc.
Win7 64-bit, 8Gb RAM, Intel Core i5-2410M 2.9GHz
AMD Radeon HD6850M 2Gb DDR5 RAM
750Gb HDD, 12% full
19. Re: "Lightroom 64-bit has stopped working"
Dustywoodbooger Feb 3, 2012 12:59 PM (in response to +becs)Can you explain the preferences thing abit more? I have tried to find this thred under users/username/appdata, etc for over 2 hours and can't find any such thing on my computer. I'm getting ready to give up on this program.
20. Re: "Lightroom 64-bit has stopped working"
+becsFeb 3, 2012 1:01 PM (in response to Dustywoodbooger)
Not sure if you are on Mac or Windows - but this kb article explains where to find the preferences files for any OS: http://kb2.adobe.com/cps/843/cpsid_84313.html
21. Re: "Lightroom 64-bit has stopped working"
Dustywoodbooger Feb 3, 2012 1:04 PM (in response to +becs)I have p.c window 7. I have printed the page you refer to, I must be a real idiot, because it still makes no sense to me. I have typed that address into every search box I can find and it leads me nowhere. Can you hold my hand abit more?
22. Re: "Lightroom 64-bit has stopped working"
+becsFeb 3, 2012 1:16 PM (in response to Dustywoodbooger)
Sure, I'll give it a try.
1. Go to your Start menu
2. In the search box, type C: (this will open an explorer window showing you the contents of your hard drive)
3. Double click on Users
4. Locate the folder associated with your username (for example, mine is "becs"). Double click on that
5. Now double click through the following folders: AppData > Roaming > Adobe > Lightroom > Preferences to locate your preferences file.
Note - the AppData folder is hidden by default on Windows 7, so it may not appear for you. If that is the case, you can change the visibility in Control Panel under Folder Options. Go to the View tab and change the setting to "Show hidden files, folders, and drives (about the 6th item down in the list).
23. Re: "Lightroom 64-bit has stopped working"
Dustywoodbooger Feb 3, 2012 1:38 PM (in response to +becs)+becs, that did it. I kept getting stumped at my user name, there was never aa appdata behind it, thought i was losin' it. Did what you said, deleted my pref and I'm runnig again. THANK you very much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
24. Re: "Lightroom 64-bit has stopped working"
Dustywoodbooger Feb 3, 2012 1:39 PM (in response to Dustywoodbooger)Now, I don't suppose you could tell me exactly what I did wrong before I go to import a new file and screw it all up again?
25. Re: "Lightroom 64-bit has stopped working"
Hal P Anderson Feb 3, 2012 1:58 PM (in response to Dustywoodbooger)It just seems to happen occasionally to a small subset of the user community. I don't think anybody knows how to make it happen. If they did, somebody like +becs would fix things in LR so that it doesn't happen.
Best I can tell you is not to worry about it.
Hal
26. Re: "Lightroom 64-bit has stopped working"
Dustywoodbooger Feb 3, 2012 2:05 PM (in response to Hal P Anderson)If it happens again, is the repair always the same?
27. Re: "Lightroom 64-bit has stopped working"
Hal P Anderson Feb 3, 2012 2:28 PM (in response to Dustywoodbooger)Most things that get fixed by deleting the Preferences file don't seem to recur. (Either that or people already know what to do and don't come here for help, which is entirely possible, now that I think about it. )
It's one of those fixes that works sometimes, so keep it in your tool kit.
Hal
28. Re: "Lightroom 64-bit has stopped working"
OldSteve2 Feb 11, 2012 10:52 AM (in response to Hal P Anderson)'people already know what to do and don't come here for help' I have exactly the same problem with 3.6 (bought Lightroom 3 as a final product, no messing with Betas) on a 64 bit PC. I delete AGPREFS over and over again, but the problem comes back. I came here hoping for a slicker soluton.
29. Re: "Lightroom 64-bit has stopped working"
Hal P Anderson Feb 11, 2012 11:26 AM (in response to OldSteve2)Steve,
Try this. (Courtesy of Beat Gossweiler)
http://forums.adobe.com/message/3671450#3671450
It could be that you are repeatedly incorrectly trying to create a catalogue and ending up with an invalid one, as explained in that thread.
Hal
30. Re: "Lightroom 64-bit has stopped working"
OldSteve2 Feb 13, 2012 8:51 AM (in response to Hal P Anderson)Thanks, but I the thread refers to an error message that names the invalid file name - I do not get any message other than '.....not responding' How can I find out the name of the catalog/ file that is causing the problem? I had hoped that my latest deletion of LRCAT had done the trick, but I am back to normal today. Is this a way to get us to buy Lightroom 4?
31. Re: "Lightroom 64-bit has stopped working"
+becsFeb 14, 2012 3:24 PM (in response to OldSteve2)
Steve,
You should never delete the .lrcat file, unless you know you don't want it. That's the file where all the changes (metadata, keywords, develop changes) are stored. If you need to troubleshoot Lightroom with a different .lrcat file, then rename or move the existing .lrcat file until you can verify that it isn't one you want to keep.
Try holding down the ctrl key while starting Lightroom. You should be prompted to select a catalog file. That dialog also gives you the option to create a new catalog file. Try creating a new catalog, and see if that works. If Lightroom starts, then you can try the same set of steps, but select an existing catalog. This will allow you to bypass a faulty catalog if that is causing the problem.
if the problem persists, can you be more specific about what you are doing in Lightroom when the error appears?
32. Re: "Lightroom 64-bit has stopped working"
OldSteve2 Feb 16, 2012 2:39 AM (in response to +becs)Thanks - for your help. Apologies, I meant I had deleted AGPREFS, not LRCAT. The problem occurs when I import. The CPU graphs shown by Task Manager show minimal use, so I guess the PC waiting for something.
The exact monment occurs when I click on Import and select one or more photos. If the photo is on an internal hard disk, after a delay of about 3 minutes the system returns to normal; an external disk or card freezes Lightroom for much longer, maybe 10 minutes or more. The problem is not that the system is waiting for an external hard disk that is switched off - it is the same whether my backup disks are on or off. Whilst Lightroom is showing "Lightroom 64 has stopped working" I can switch to other applications and they work normally.
33. Re: "Lightroom 64-bit has stopped working"
jturnerstarcruiser Apr 21, 2012 12:45 PM (in response to +becs)Excellent! Thanks +becs and the rest of you... this worked!!!
