1. Re: can't export with same settings.
JSS1138 Feb 15, 2012 10:02 PM (in response to robirdman1)it doesn't work. Why not?
Unknown (error).
2. Re: can't export with same settings.
robirdman1 Feb 16, 2012 5:39 AM (in response to JSS1138)If I knew why I get "error compling movie. Unknown error" then I wouldn't be posting on the forum.
3. Re: can't export with same settings.
Ann Bens Feb 16, 2012 5:51 AM (in response to robirdman1)http://kb2.adobe.com/cps/906/cpsid_90670.html
Dont use match sequence settings, either use a preset or set everything manually.
4. Re: can't export with same settings.
robirdman1 Feb 16, 2012 8:02 AM (in response to Ann Bens)As I looked at the list of possible reasons, the 2nd one jumped out at me as I was exporting to the same name. Unfortunatley that wasn't the problem. Checking the other ones:
Disk has plenty of space.and none of the other things are problems as I can export things without matching settings.
As in the test, there was no other clip or modifications that is not the problem. I tried several other clips from the D300s and the results are always the same. There is no ability of the program to match the sequence settings. Checking this box is why it won't work.
The last suggestion is to post the problem to the user forum so here it is in a perhaps endless loop with no solution other than PP just can't do it.
5. Re: can't export with same settings.
JSS1138 Feb 16, 2012 10:12 AM (in response to robirdman1)If I knew why
What I'm saying is, we don't know either. There is not a definitive cause for the unknown error message that we can say to you, "do this and it'll work".
