RH 9 / WebHelp output
I added twisties to my project a couple of weeks ago and they worked fine.
Recently I re-organized my images and the twistie graphics were not displaying so I went into the css and updated the path.
The collpage icon displays fine, but the expand will not. I even tried using the collapse icon for the open icon and it still won't display. I put the images back at the root and re-did path, and nothing changed.
Attached pictures of the 2 outputs, and the code.
Have a release going out tomorrow so any help much appreciated.
here's the css
Hi there
Perhaps try using the file browsing icon (folder) and re-select the image?
Just thinking out loud.
Cheers... Rick
I've done that a couple of times to no avail.
Hello again
I think the next approach I would suggest would be to choose a different pair of images. See if things correct then. And if so, re-select the desired images.
If that fails, you need to examine the CSS at the code level. I know you probably think you have posted that, but what I mean is to open the CSS file in Windows Notepad and note what is shown there.
Cheers... Rick
I re-directed them both to a new file. Collapse works, Expand doesn't.
Here's the css for the hotspot.
Hi there
For starters, the CSS seems that you are referencing the same exact file. So your Expand and Collapse should be identical. But in your screen capture, it appears that the collapse isn't showing?
If you are really wanting the same image, perhaps make a copy and name the copy slightly differently. Then specify it in the CSS editor or code.
Another thing to try is to right-click and add both images to your project as Baggage files.
Cheers... Rick
I thought of deleting the images and starting over but you can't select "no image" from in RH.
Should i try just deleting those two lines for the images from the css, and then re-doing them in RH ?
