When using LiveCycle 9 action builder, I can make objects invisible (button click) with no problem. But then when I try action builder to make the same objects visible with another button click action, it doesn't work. I could use some ideas what might be wrong.
Total Likes
More information.
1. When I designate an object "invisible" during composing I cannot get it to then show programatically with a button click.
this.resolveNode("countryCodeDropdown").presence = "visible"; (Doesn't work)
2. However, if I render that object "invisible" programatically, then I can get it to show programatically.
This code in a "change" script makes the same object invisible.
this.resolveNode("countryCodeDropdown").presence = "invisible";
and now, this button-click code works. (Same code as above)
What is different?
I've tried setting the object visible in composing and making it invisible when the form loads, but then it will not unhide.
Total Likes
