1. Re: Flash Builder 4.6 and CS Extension Builder 1.5
Meriturva Feb 12, 2012 11:36 PM (in response to PhotoSì)The same problem here.....no solution at all?
Meriturva
2. Re: Flash Builder 4.6 and CS Extension Builder 1.5
emerasoft.srl Feb 17, 2012 1:59 PM (in response to Meriturva)It's a no way. If you would like to use the "design mode", revert to FB 4.5.1
Luca
3. Re: Flash Builder 4.6 and CS Extension Builder 1.5
Meriturva Feb 28, 2012 5:13 AM (in response to emerasoft.srl)Seriously? Adobe has to update something to have design working on latest versions!
4. Re: Flash Builder 4.6 and CS Extension Builder 1.5
flosen spierala Mar 30, 2012 2:38 AM (in response to PhotoSì)Crazy, it´s still not fixed! 4.6 and CSEB 1.5 with black screen in Design Mode. Is actually someone using it seriously? makes me doubt! cheers, florian
5. Re: Flash Builder 4.6 and CS Extension Builder 1.5
Harbs. Mar 30, 2012 3:57 AM (in response to flosen spierala)It's not going to be fixed.
The only version of FB where design mode really works is 4.0. Even in 4.5, it's very fragile for Flex 3. (Flex 4 should work fine.)
Yes. I use EB 1.5 all the time. The lack of a working Design Mode is annoying and makes devlopment somewhat less efficient, but it's not a show-stopper...
Harbs
6. Re: Flash Builder 4.6 and CS Extension Builder 1.5
Toto RoToTO Apr 6, 2012 6:27 AM (in response to Harbs.)Harbs: Why this bug would not be fixed? Adobe is not making developments or corrections on FlashBuilder?
This bug is pretty annoying. It makes building interfaces slower and not efficient at all.
7. Re: Flash Builder 4.6 and CS Extension Builder 1.5
flosen spierala Apr 23, 2012 4:06 AM (in response to PhotoSì)I was lucky that I found a Flash Builder 4 PlugIn in my Eclipse. There Design View seems to work...
But I still can´t believe that Adobe won´t fix such a big and annoying BUG!
Florian
8. Re: Flash Builder 4.6 and CS Extension Builder 1.5
mackry88 Jun 6, 2012 9:08 PM (in response to PhotoSì)How are we to make interfaces? And how is this not a show-stopper?
9. Re: Flash Builder 4.6 and CS Extension Builder 1.5
Harbs. Jun 7, 2012 12:09 AM (in response to mackry88)Programatically.
For CS6 you can use Spark components. Those work in the design view fine.
Harbs
10. Re: Flash Builder 4.6 and CS Extension Builder 1.5
Harbs. Jun 7, 2012 12:36 PM (in response to mackry88)You can also try making a non-CS SDK project to build the UI, and copy the assets from there.
