I've been struggling with reading a 3rd party product feed.
I'm using the following code
<cfhttp url="http://webservices...."> |
<cfhttpparam type="header" name="accept-encoding" value="deflate;q=0">
<cfhttpparam type="header" name="te" value="deflate;q=0">
</cfhttp>
<cfdump var="#cfhttp#"> |
It returns with
struct | |||||||||||||||||||||
Charset | utf-8 | ||||||||||||||||||||
ErrorDetail | [empty string] | ||||||||||||||||||||
Filecontent | Connection Failure | ||||||||||||||||||||
Header | HTTP/1.1 200 OK Content-Type: text/xml; charset=utf-8 Date: Sat, 18 Feb 2012 13:42:00 GMT Cache-Control: private, max-age=0 X-AspNet-Version: 4.0.30319 Server: Microsoft-IIS/7.0 X-Powered-By: ASP.NET | ||||||||||||||||||||
Mimetype | text/xml | ||||||||||||||||||||
Responseheader |
Statuscode | 200 OK | ||||||||||||||||||||
Text | YES |
If use Firefox Live Headers plugin and view the feed in the browser, it displays fine and also the plugin gives me the information
GET /services/products.asmx...... HTTP/1.1
Host: webservices.......
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:10.0.1) Gecko/20100101 Firefox/10.0.1
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-gb,en;q=0.5
Accept-Encoding: gzip, deflate
Connection: keep-alive
Cache-Control: max-age=0
HTTP/1.1 200 OK
Content-Encoding: deflate
Date: Sat, 18 Feb 2012 13:34:09 GMT
Content-Length: 9225
I've googled and tried variation of accept-encoding to no avail, I just get connection failure.
Any ideas? Thanks
p.s. also tried
<cfhttpparam type="header" name="accept-encoding" value="no-compression"/>
Have you tried with no headers at all? Can you browse the webservice from the ColdFusion server? It seems a little odd that it's getting a 200 but giving you back "Connection Failure" - that would imply it's something in their software that's throwing that message rather than the HTTP transaction.
Is there any documentation that says what you need to send?
Tried without httpheaders, the same result.
Added throwonerror and it gives the error "Connection Failure: Status Code Unavailable"
I haven't got access to the ColdFusion server, however I tried it on another CF server to the same affect. I'll install the developer edition on my local PC and retry.
I will see if I can find any documentation.
Tested on local PC with CF9 dev server, same issue.
Documentation does not suggest anything that might help.
I agree with Owain. The combination of a 200 OK status and cfhttp.filecontent of 'Connection Failure' implies you got a response back, and the response had the message 'Connection Failure' as its only content.
The content-type is XML, which raises the question, is the service expecting your request to be SOAP? Could we have a look at your cfhttp code?
Well it appears to accept SOAP or HTTP requests.
That last dump was product of this code
cfsavecontent variable="soapBody">
<Cfoutput>
<?xml version="1.0" encoding="utf-8"?>
<soap12:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap12="http://www.w3.org/2003/05/soap-envelope">
<soap12:Body>
<GetCategoryList xmlns="http://xxxx.com/">
<apiKey>xxxx</apiKey>
<clientID>xxxx</clientID>
</GetCategoryList>
</soap12:Body>
</soap12:Envelope>
</cfoutput>
</cfsavecontent>
<cfhttp url="http://webservices.xxxx.com/services/products.asmx"
method="post" result="httpResponse">
aram
type="header"
name="SOAPAction"
value="http://webservices.xxxx.com/services/products.asmx/GetCategoryList"
<cfhttpparam
type="header"
<cfhttpparam
type="xml"
value="#trim( soapBody )#"
</cfhttp>
<cfdump var="#httpResponse#">
It is usually important to have no characters between the cfsavecontent tag and the XML declaration. Here follows the solution to a similar webservice problem in this forum:
<!--- WSDL --->
<cfset wsdl_url="http://dwc-dreiman-w7e/WSExchangeMeetingRooms/exchange.asmx?WSDL">
<cftry>
<!--- Compose SOAP message to send to Web Service--->
<cfsavecontent variable="soap"><?xml version="1.0" encoding="UTF-8" ?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<ns:requestParameterName soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns="http://your_own_namespace_url">
<c xsi:type="xsd:string">bkbk</c>
<d xsi:type="xsd:string">test message from bkbk</d>
</ns:requestParameterName>
</soapenv:Body>
</soapenv:Envelope>
</cfsavecontent>
<!--- Invoke web service to send message--->
<cfhttp url="#wsdl_url#" method="post" >
<cfhttpparam type="header" name="content-type" value="text/xml">
<cfhttpparam type="header" name="SOAPAction" value="">
<cfhttpparam type="header" name="content-length" value="#len(soap)#">
<cfhttpparam type="header" name="charset" value="utf-8">
<cfhttpparam type="xml" name="message" value="#trim(soap)#">
</cfhttp>
<p><cfoutput>#xmlFormat(cfhttp.fileContent)#</cfoutput> </p>
<cfcatch type="any">
<cfdump var="#cfcatch#">
</cfcatch>
</cftry>
I might have been approaching it wrong, it is a SOAP webservice - so I'm going to try this
http://www.bennadel.com/blog/1809-Making-SOAP-Web-Service-Requests-With-ColdFusion-And-CFHTTP.htm
well actually it supports http requests, soap 1.1 and soap 1.2
even with trying the soap approach I get
Header | HTTP/1.1 200 OK Content-Type: application/soap+xml; charset=utf-8 Date: Sat, 18 Feb 2012 15:01:56 GMT Cache-Control: private, max-age=0 X-AspNet-Version: 4.0.30319 Server: Microsoft-IIS/7.0 X-Powered-By: ASP.NET | ||||||||||||||||||||
Mimetype | application/soap+xml | ||||||||||||||||||||
Responseheader |
Text | YES |
