Hello,
I'm trying to download (from the Flash Player Distribution page http://www.adobe.com/products/flashplayer/distribution3.html ) Flash Player 11.1.102.62 (32 bits) for Windows, in order to install it in our Company using SCCM.
But the file I get is not the correct one... it seems to be an older one, not the 11.1.102.62 (even if I click on the line "Flash Player 11.1.102.62 (32 bit) for Windows").
So, it seems the webmaster may have made some misstake.
Thanks to correct it
I just downloaded all four 32-bit installers for Windows; see details below.
Name | Size | File Version | Timestamp |
install_flash_player_11_active_x_32bit.exe | 3.62 MB (3,803,296 bytes) | 11.1.102.62 | 2012-02-14 12:41:53 |
install_flash_player_11_active_x_32bit.msi | 4.64 MB (4,867,072 bytes) | 2012-02-14 12:41:26 | |
install_flash_player_11_plugin_32bit.exe | 3.59 MB (3,765,920 bytes) | 11.1.102.62 | 2012-02-14 12:44:45 |
install_flash_player_11_plugin_32bit.msi | 4.60 MB (4,828,672 bytes) | 2012-02-14 12:44.14 |
If you get different versions, then you may have an old version cached somewhere.
And here are the details for the 64-bit installers:
install_flash_player_11_active_x_64bit.exe | 7.83 MB (8,211,104 bytes) | 11.1.102.62 | 2012-02-14 11:00:37 |
install_flash_player_11_active_x_64bit.msi | 8.97 MB (9,406,464 bytes) | 2012-02-14 12:49:40 | |
install_flash_player_11_plugin_64bit.exe | 7.74 MB (8,124,064 bytes) | 11.1.102.62 | 2012-02-14 10:43:05 |
install_flash_player_11_plugin_64bit.msi | 8.88 MB (9,318,400 bytes) | 2012-02-14 12:51:21 |
