Remote Call Object too big?
Avatar
Former Community Member
I'm using data services on an application and I have a remote
call that is getting hung up before it invokes a call to the
server. I've modified the function to pass a String and that works
fine but when I'm trying to pass a large object the "invoke" event
is never thrown by the remote object when I use the large object in
my remote call.
Is there a size limit for objects being passed as function
parameters?
Avatar
Level 3
How did you generate or load the data in the first place? Are
you using DataService or RemoteObject? Any idea how big this object
is in terms of bytes or numbers of members of an Array, etc? Are
you using ArrayCollection or just plain old Array? Does it make a
difference if you switch between the two? If it's RemoteObject,
have you considered setting makeObjectsBindable to false to see if
it makes a difference?
There are theoretical limitations to certain data types but
they would be hard to reach, it would most likely be a circular
dependency somewhere that is breaking serialization. While circular
references are supported, custom serialization using
IExternalizable may circumvent reference checking based on the
custom encoding format.
Note out of interest that based on AMF encoding you are
limited to around 256MB for an individual String or ByteArray,
around 256 million unique object or string instances (as reoccuring
instances are sent by reference), around 256 million array entries,
around 33 million property names on an object, etc.
Avatar
I fixed my problem, but I think it might mean something else
underlying was going wrong. I had an ArrayCollection of custom
objects that also had a couple ArrayCollections of custom Objects.
For some reason one of the inner collections wasn't getting turned
into its "AS clone" when I retrieved the object from the server. So
when I tried to use that same object to pass back to the server the
app would freeze even before the remoteobject call. After I was
able to force the correct object type it ran fine.
Avatar
Level 3
I'd be very interested in tracking down this exact issue if
you have the time to send me some code that would reproduce the
issue (or at least perhaps a dump of the object graph to explain
the relationship between the collections, inner and outer, and the
custom objects).
You can email it to me at pfarland@adobe.com if you
like.
