13 Replies Latest reply: Feb 23, 2012 1:43 AM by Sandeeppaliwal RSS
    Some Questions on CF10 > Server Update > Updates
    carl type3 Community Member
      The "CF10 feature PDF" says:
      Server update... The updates can include hot fixes and security hot fixes for ColdFusion 10.
      Will traditional "CF updaters" be a separate process apart from hotfix, cumulative hotfix and security update eg  ColdFusion 9 Update 1 (9.0.1)?
      Will the update type be specific and say-
      Update Type: cumulative or hotfix or security?
      Previously patch order had a bearing on the wellbeing of CF. For instance one would elect to install say updater1 followed by cumulative hotfix  then subsequent security patch eg CF9.0.1, CHF1, APSBxx-xx. Will CF10 updater manage patch order or prerequisites not allowing incorrect update order?
      Thanks, Carl.
        • 1. Re: Some Questions on CF10 > Server Update > Updates
          The CF10 update using HotFix hf-zeus-00001 did not apply for me. How have others gone with applying HotFix hf-zeus-00001 update?
          Server Update > Updates says:
          UpdatesInstalled
          Error Occurred while reading update information - An error occured while Parsing an XML document.
          Debugging & Logging > Log Files > update.log  says:
          Successfully downloaded hotfix_0001.jar at C:\ColdFusion10\cfusion\hf-updates
          Tried to apply HotFix hf-zeus-00001 update manually:
          CMD
          C:\ColdFusion10\cfusion\hf-updates>
          C:\ColdFusion10\cfusion\hf-updates>echo %JAVA_HOME%
          C:\ColdFusion10\jre
          C:\ColdFusion10\cfusion\hf-updates>echo %PATH%
          C:\Windows\system32;C:\Windows;etc;C:\ColdFusion10\jre\bin
          C:\ColdFusion10\cfusion\hf-updates>java -jar hotfix_0001.jar
          Prompts for Where is ColdFusion Zeus located
          Offering
          C:\ColdFusionZeus
          Change that detail to correctly match setup
          C:\ColdFusion10
          The install seems to complete offering - Install Complete.
          Tho upon logging in to CF Server Update > Updates  does not show update installed.
          Things noticed
          -ColdFusion 10 Application Server stops
          -ColdFusion 10 Application Server reports as being started
          -CFadmin keeps responding:
          Service Temporary Unavailable!
          The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
          Action taken
          -Wait 15 minutes restart ColdFusion 10 Application Server
          -Read thru Adobe_ColdFusion_Zeus_HotFix_1_Install_date_time.log seems to indicate success
          Thanks again, Carl.
          • 2. Re: Some Questions on CF10 > Server Update > Updates
            rupesh_kumar Adobe Employee
            Carl, we will check this and get back to you on this.
            • 3. Re: Some Questions on CF10 > Server Update > Updates
              Hi Rupesh,
              Thought I would try CF10 Server Manager AIR app to apply HotFix however option is greyed out:
              Thanks once more, Carl.
              • 4. Re: Some Questions on CF10 > Server Update > Updates
                Sandeeppaliwal Community Member
                Hi Carl,
                Form ColdFusion 10 onwards, all updates will be cumulative. This means that all fixes of previously relased hotfix be included in any new hotfix which comes later.
                Also the previous process of deploying jar files in through Server Manager won't be relevant with ColdFusion 10 as now hotfix jar will be full installer(unlike previous hotfixes which required copying them to lib/updates folder in CF server).
                Regarding the error with current hotfix, we are in prcess of updating new test hotfix which will be compatible with the beta release. If you have installed he current one, you can unistall it with uninstaller placed under <CF-HOME>/cfusion/hf-updates/<hotfix name> folder or through Admin (under Installed updates tab on updates page).
                thanks,
                Sandeep Paliwal
                Adobe ColdFusion team
                • 5. Re: Some Questions on CF10 > Server Update > Updates
                  Nice
                  OK
                  >process of updating new test hotfix which will be compatible
                  Let me know when it is posted so I can try it.
                  Thanks for prompt response, Carl.
                  • 6. Re: Some Questions on CF10 > Server Update > Updates
                    Hi Sandeep,
                    The online help indicates CF10 Server Manager can be used to apply updates?
                    http://help.adobe.com/en_US/ColdFusion/10.0/Admin/WSfd7453be0f56bba4-2a6b48f122a6582c7f-7f f6.html
                    Heading  "Apply hot fix"
                    "You can update multiple ColdFusion Server instances, once they are registered with Server Manager."
                    Regards, Carl.
                    • 7. Re: Some Questions on CF10 > Server Update > Updates
                      Hi Carl,
                      We have updated test hotfix compatible with ColdFusion 10 Beta.
                      If you have installed the previously available hotfix, make sure you uninstall it, else latest one be shown as available one for download in CF Admin.
                      thanks,
                      Sandeep Paliwal
                      • 8. Re: Some Questions on CF10 > Server Update > Updates
                        Thanks Carl for pointing this out.
                        We will update Server manager docs to reflect the new change.
                        Please feel free to log a bug for this.
                        thanks,
                        Sandeep Paliwal
                        • 9. Re: Some Questions on CF10 > Server Update > Updates
                          Hi Sandeep,
                          Great that worked!
                          Server Update > Updates > UpdatesInstalled says:
                          HotFix hf-10-00001 Fri, 17th Feb 2012
                          Update Level: 01
                          Update Type: Cumulative
                          Install Date: Wed, 22 Feb 2012 17:18:02 +1000
                          Update Description:
                          This is ColdFusion 10 Beta cumulative hotfix 1.
                          This is a test hot fix created to get used to new hotfix installer feature.
                          Backup Directory: C:\ColdFusion10\cfusion\hf-updates\hf-10-00001
                          Install Log: C:\ColdFusion10\cfusion\hf-updates\hf-10-00001\hotfix_filelist.log
                          Server Settings > Settings Summary says:
                          System Information
                          Server Details
                          Server Product  ColdFusion
                          Version  ColdFusion 10,281485
                          Edition  Enterprise (Trial)
                          Operating System  Windows 7
                          OS Version  6.1
                          Update Level  /C:/ColdFusion10/cfusion/lib/updates/chf10000001.jar
                          Adobe Driver Version  4.1 (Build 0001)
                          How does one correlate the update level report differences between "Server Update > Updates >
                          UpdatesInstalled" and "Server Settings > Settings Summary > Update Level"?
                          Thanks much, Carl.
                          • 10. Re: Some Questions on CF10 > Server Update > Updates
                            Hi Sandeep,
                            Further when I ran remove update from:
                            The dialog prompted that CF10 would restart. It stopped however did not start. Run SERVICES.MSC and started "ColdFusion 10 Application Server".
                            Should the dialog be changed or was there a problem and you would expect CF10 to start without intervention after update removal?
                            • 11. Re: Some Questions on CF10 > Server Update > Updates
                              Currently there is issue with update uninstaller which does not restart CF server post uninstall.
                              We are aware of the bug, and it should be fixed going forward.
                              thanks,
                              Sandeep Paliwal
                              • 12. Re: Some Questions on CF10 > Server Update > Updates
                                Hi Sandeep,
                                CF updating appears a much simpler task in CF10 versa CF9,8,7. To update via CFadmin or “manual method” both work without messing about performing Unzip file copy steps.
                                Like CF10 Server Update.
                                • 13. Re: Some Questions on CF10 > Server Update > Updates
                                  Thats great to hear.
                                  Thanks a lot for your feedback on this.
                                  -Sandeep Paliwal
