Looking for advice/tips regarding a potential upgrade from RoboHelp x5 to RoboHelp 9.
Currently:
Projected upgrade path:
Thoughts, issues, concerns, advice?
If you are using DHTML dropdowns you should be aware that the content of these is not included in any review documents you generate in RoboHelp. Something to bare in mind if you want to use this RH9 functionality. Apart from that you should be OK.
The RoboColum(n) | @robocolumn | Colum McAndrew |
You will likely also encounter issues with lists. RoboHelp 8 changed to XHTML and that broke lists for quite a few people. If you do encounter that problem, the fix is on my site.
There are also topics about the issues with RoboHelp 7, 8 and 9. Not all the issues 7 and 8 had will apply as a good few were fixed in patches and upgrades.
Colum and Peter,
Thank you for the prompt responses. We are using DHTML dropdowns. Since I'm intrigued by the review functionality in RH9 your information is good to know. If that feature works as well as I hope it does, I think the drop-down issue is something our writers will be happy to deal with.
Fortunately, we use inline lists so that issue doesn't appear to be a problem.
Jason
What do you mean by "inline lists"?
We don't use style sheet defined styles for them. We create/format each list manually.
Then don't consider yourself immune.
It's the way RoboHelp 5 wrote the HTML that can cause a problem.
