Thanks to your advice, was able to use WebCharts3D to control
"most" attributes in my line chart (using CF 7.0.2, Win2K, SQL
Server, IE7, Firefox 2). Am creating my own chart style XML files,
and calling them in the CFCHART tag.
For example, can control appearance of X and Y axis labels
and titles (e.g., horizontal, vertical, spacing, etc.). So far, so
good.
BUT I STILL HAVE NO CONTROL OVER THE FONT SIZES OF VARIOUS
ITEMS IN MY CHART. Even after removing the "font size" attribute
from the <CFCHART> tag, EVERYTHING SHOWS UP IN THE SAME FONT
SIZE.
For example, I need my chart's title to display in 24 point
ARIAL, and would like the X and Y axis titles to display in 16
point ARIAL. But somehow, EVERYTHING (all text) is displayed in 12
point ARIAL when I execute the CF chart template.
What is strange, is that when working in WebCharts3D, the
chart title ON THE SCREEN IS DISPLAYED IN THE LARGER FONT. It's
just that it won't display in the larger font when running the CF
chart template.
Is this the way WebCharts3D is supposed to work? Or should
you be able to set different font sizes for different chart
elements, using WebChart3D's XML styles? If so, is there some
setting in WebCharts3D that allows you to do this, and somehow
disables a "FIXED FONT SIZE" for all chart elements?
Thanks for any help, advice.
Gary
