one way could be to pass the tab state in a hidden form
field:
you would need to set a variable to the current tab state
<cfset tabname = "thetabid">
then add a hidden field to your form
<form>
<input type="hidden" name="tabtoload"
value="<cfoutput>#tabname#</cfoutput>">
</form>
then towards the top of the page, when it it reloaded, check
to see that
a value is passed, and if so call the right tab. note, not
sure how
you're doing the tabs so alter that part....
<cfparam name="form.tabtoload" default="">
<cfif LEN(form.tabtoload) GT 0>
<!--- call tab --->
<!--- insert appropriate code here.... --->
<cfoutput>#form.tabtoload#</cfoutput>
<cfif>
hope that helps. im sure there are other ways to do it
too.....
Wally Kolcz wrote:
> Is there a way to maintain the tab you are on after
submitting a form that
> returns to the same page and after the form reloads?
