3 Replies Latest reply on Jun 18, 2013 5:54 PM by George-R
    Adding Unit testing to a CS Extension Project
    stevoad
      I'm working on a CS extension project, and I'd like to add unit testing to the project. I see that the extension project doesn't support FlexUnit. Is there a way to add unit testing to a extension project?
      Stephen
        • 1. Re: Adding Unit testing to a CS Extension Project
          Bob Stucky Adobe Employee
          You can certainly use FlexUnit. Add the libraries to your project and test away.
          What we normally do, depending on the overall project requirements, is put as much of the core/logic as we can in a library. Then we write both an Air app and an Extension that are intended to execute unit tests against that library. The Air app tests the functionality that is not dependent on a host application (PS, AI, ID...).
          Depending on your project, you may or may not be able to use an Air app for testing (CSXS calls are not supported from Air).
          • 2. Re: Adding Unit testing to a CS Extension Project
            Toto RoToTO Level 3
            Hello Bob.
            Is it planned to handle Creative Suite Extension project in FlexUnit?
            Thx,
            Thomas.
            • 3. Re: Adding Unit testing to a CS Extension Project
              George-R
              Another option is to abstract the API objects into interfaces, only adding the functionality you need, and mocking those with something like mockolate to do your tests. It doesn't work for everything, but it covers a lot more than the CSEB independent stuff.
              As an example, I have IApplication, with an activeDocument getter that returns IDocument. The implementations are handled by a service locator, so my extension uses actual API objects, and my test project uses mocks - easy!
