I'm trying to use the Flash builder 4.5 + flex 4.0sdk profiler on a moderate size project suffering from what is probably a rather complex (and urgent) memory leak.
Selecting memory, but not performance profiling, before taking a memory snapshot or any other explicit profiler action, I run into this error:
ReferenceError: Error #1037: Cannot assign to a method hasOwnProperty on flash.utils.Dictionary.
at ProfilerAgent/collectSamples()
at ProfilerAgent/timerHandler()
at flash.utils::Timer/_timerDispatch()
at flash.utils::Timer/tick()
This is probably very similar to this:
http://forums.adobe.com/message/2719370#2719370
and this bug:
https://bugs.adobe.com/jira/browse/FB-29303
However, this jira says that this is fixed, so It's a bit odd to see this issue in FB 4.5.
Any suggestions/workaround would be most welcome.
Best,
Ian
Hi Ian,
Can you send a sample test case to try it on here locally. Do let me know by mailing me on: angaurav at adobe dot com.
+Anand
Hey,
Did anyone resolved this problem? I have the same problem and cant figure out a workaround for this problem. Any help is greatly appreciated.
the same problem, flash builder 4.5
