I have a current project that I want to change the way the slides advance. Right now its on "on mouse click" to advance the slides and I want to change it to "automatically" advance. How do I do that without redoing the whole project?
I'm assuming from your reference to On Mouse Click and Automatic that this is a project which you have created with PPT and Captivate?
If so, when you imported the PPT slides you must have selected the On Mouse Click option. This results in each slide having a click box object that pauses the slide and listens for a mouse click event to allow Continued play. Just locate this click box on each slide and delete it.
And before you ask...no, there's no way to do this across all slides in one go. You need to manually remove the click box on each slide.
If this would be too time consuming, your quicker solution might just be to reimport the original slides and make sure you select the Automatic advance instead.
Hi there
In addition to what Rod offered, another possible quick and painless solution would involve displaying the properties for one of the Click Box objects. Clear the option to Pause project until user clicks, then use the Apply to All button to configure the other Click Boxes the same way.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Just one more thing: If you use Rick's suggestion of changing the settings for all click boxes in the project, any click boxes that you WANTED to pause the project will stop pausing as well. If there are none that need to pause at any point, this is not an issue.
How do I enable this option in my project - I want to advance ONLY when the user clicks.
Your screen versus my screen
Yours:
My Screen: (I do not have Mouse Option)
Your screen is showing properties for the Slide while mine is showing properties for a Click Box.
If you insert a Click Box, you will then see similar properties.
Cheers... Rick
This is a project using ppt but there are no click boxes. This is just suppost to be a rolling presentation. Any suggestions?
Can you show us a screenshot of the timeline objects for one of the slides that is currently pausing?
I got it. This was actually someone else's projecct and she said there were no click boxes but there were. These suggestions worked. Thank you very much for your help.
