1. Re: URGENT-Warp effect tool illustrator, I want to arc an image
MichaelKazlow Feb 24, 2012 10:57 AM (in response to jakki999)Please post Illustrator questions in the Illustrator forum. This is a forum dedicated to design issues.
2. Re: URGENT-Warp effect tool illustrator, I want to arc an image
Jacob Bugge Feb 24, 2012 3:00 PM (in response to jakki999)1 person found this helpfulJackie,
When you following the suggestion by Michael and repost here,
http://forums.adobe.com/community/illustrator/illustrator_general?view=discussions
one of us shall tell you that to change the shape of a raster image, such as a TIFF, as described you may create a (vector) path with the same size and shape placed right on top of the image, and then select both and Effect>Warp>Arc. You can just select the image and see the position and size in the Transform while you create the rectangle to fit.
3. Re: URGENT-Warp effect tool illustrator, I want to arc an image
jakki999 Feb 25, 2012 4:29 AM (in response to Jacob Bugge)Thank you Jacob, that is what I was doing, what I failed to do was to embed the image first, once embedded it worked perfectly!!!
Jackie
4. Re: URGENT-Warp effect tool illustrator, I want to arc an image
jakki999 Feb 25, 2012 4:35 AM (in response to MichaelKazlow)Whoops, sorry Micheal, I have put it in the illustrator forum with the question answered in case anyone else made the same mistake, hope it is helpful.
5. Re: URGENT-Warp effect tool illustrator, I want to arc an image
Jacob Bugge Feb 25, 2012 5:05 AM (in response to jakki999)You are welcome, Jackie, but it should work with a linked image, see over there.
And sorry Michael, but it did get moved.
