How do I import .AVI files into Premiere Pro CS5?
Dec 26, 2011 Dec 26, 2011
Hello
I have just got myself a new Toshiba Camileo X100 and it shoots in 1080i60 and the raw video files are in an .AVI format there are also backups stored as thm.AVI. When I try to import these files into Premiere on my Macbook Pro I get an error message saying "codec missing or unavailable."
What do I need to do to be able to Import these files? I have searched this forum and googled everything I could think of. One post suggested trying VLC so I tried it that way but my mp4 files that converted through VLC were only sound files instead of both video and audio. I need some sort of way to either convert or import a different way without losing much quality....
This is really bothering me, help would be appreciated.
113.6K
This information may help
Codec: H264 - MPEG-4 AVC (Part 10)
Resolution: 1920x1080
Frame Rate: 29.970030
Audio Codec: MPEG AAC Audio (mp4a)
Sample Rate: 48000 Hz
Feb 25, 2012 Feb 25, 2012
I am having the same problem with Premiere Pro CS5.5 on Win 7 with an avi from the RD32II 1080p .h264 Sport Cam from Redleaf. There is no info on the Redleaf website (www.hkredleaf.com) about the codec.
The file plays in Windows Media Player and VideoLAN Player, but Prem Pro imports the audio only.
These are the file properties revealed by MediaInfo:
AVI, 1 video stream AVC, 1 audio stream ADPCM
video: 1920*1080 (16:9), at 29.970 fps, AVC (Main@L4.0)(CABAC / 4 Ref Frames)
audio: 192kbps, 48.0 KHz, 4 bits, 1 channel, ADPCM (Intel)
I downloaded various ffmeg zip files and extracted them.
     FFmbc-0.7-rc5
     ffmpeg-git-b6ff81d-win64-static from ffmpeg.zeranoe.com
          and based on the link from MediaInfo,
     last_x264 from VLan which appears to be an encoder and not decoder.
Not having install instructions (or anything specifically relevant to Win7) that I could find in those zip files I do not know if the codec has been installed correctly or not.
I tried the avi2mp4 BAT file aproach in the same folder as the file, copied the ffmpeg.exe into windows system and system 32 folders, and the BAT file.
Nothing! Same result - just the audio.
Adobe Media Encoder's conversion yield's black vision.
Can anyone tell me if I am doing something wrong or is it simply an incompatibility with Prem Pro?
Before you corrupt your whole system by trying to download codecs or codec packs, often requiring a complete format of the boot disk and full installation of OS and programs, Google for external converters to make that material editable.
Yes, your choice of camera.  Things will work better if you pair your professional level software with a professional level camera that records to a standardized recording format.
For this media, you might try a consumer level editor.  They're often more forgiving about formats.
Feb 26, 2012 Feb 26, 2012
It's is not my camera nor my choice of camera. I am dealing with a number of files supplied by the client. If you have an answer such as the codec or which edit software will work, I'd appreciate it.
Contributor ,
The only way I managed to edit with the material in "native" form was to demux the video from the original AVI file to a .264 file using MPC Home Cinema (Media Player Classic). I then imported both the original AVI, to use for audio and the new .264 to use for video. It's a bit cumbersome, but at least the quality is not degraded. Works for now, until maybe CS6 will support it...?
.....  demux the video from the original AVI file to a .264 file using MPC Home Cinema (Media Player Classic).
I have the latest version of MC Home Cinema build 1.6.0.4014 . The file plays well in that media player. How do you demux and export a .264 file?
Contributor ,
In MPC go to File- >Utils->DSM Converter
Right click in the window that pops up and select Add File.
You will see a list of available streams. Right click the stream you want and select demux.
-Although, Jeff's solution might be better for you, since you end up with one properly editable file instead!
Hi Magnus. In the MPC Home Cinema x64 version I have the Utils menu option does not seem to exist.
Contributor ,
Does it look like this?
Edit: I see on the MPC web site that their version is a lot newer than mine. I use V 1.3.1249.0
I can zip it up for you if you'd like!
Message was edited by: Magnus Allgurén
no, like this...
maybe the x32 version is different...
I use V 1.3.1249.0
Yes please, a copy of the earlier version would be welcome.
Contributor ,
I sent you a private message!
To the best of my knowledge, Pr still does not support H.264 in an AVI file.  Your best bet is to run it through VirtualDub and convert it to an AVI file with a lossless codec like Lagarith or UT.  Then use the new AVI file in Pr.
Links:
VirtualDub download (at SourceForge) - virtualdub.org
Lagarith Lossless Video Codec
Codecs.com :: Download Ut Video Codec Suite 10.2.4
-Jeff
Contributor ,
Jeff,
I just tried opening it with VirtualDub and it won't do it for me... You seem to need a third party codec to do that.
What version?  I used the 32-bit version of 1.9.11 to open one of the test clips from the site Glenn linked to and it opened and played just fine in VirtualDub.
-Jeff
EDIT: I do have the x264 vfw codec installed, so maybe that's the key.  Here's a link:
x264vfw | Free Audio & Video software downloads at SourceForge.net
Contributor ,
Me too!
Contributor ,
Jeff I installed your codec and works perfectly for the video. Vdub plays the audio fine, but when exporting to Lagarith the audio will not playback in Premiere. It only gives a blank waveform. Video plays back fine though,
I suppose I should mention that Pr doesn't like raw PCM audio in an AVI file, either.
Try this setting for the audio in VirtualDub:
It'll re-wrap the audio in a way that is Premiere Pro friendly.
-Jeff
Contributor ,
Sir, you are correct!
I guess this will conclude this session of troubleshooting?
I think that's up to Ric.
However, I'm glad it's sorted on your system.
-Jeff
I really appreciate your help in getting this workaround together.
O.K. I have downloaded all the codecs and installed VirtualDub. The file plays with audio but unevenly.
In the menu, under Audio, "Compression..." is ghosted and inaccessible.
The avi file exported appears in PremPro, but the playback is uneven - slows down and speeds up. Is that a setting that needs to be tweaked?
Contributor ,
Before you select your compression, you have to select "Full Processing" in the Audio menu. After that you can select your audio compression.
...and under Video, select "Fast recompress" for slightly faster conversion.
