This question was posted in response to the following article: http://help.adobe.com/en_US/flashbuilder/using/WSe4e4b720da9dedb5-4dd43be212e8f90c222-7ffb.html
Agreed that this could be better. I'm not sure what your exact issue is, but here are a few thoughts:
* The doc should tell you how to display the Create, manage, and run configurations panel, so it needs a "step 0":
0) Select Run > Run configurations from the menu bar
Step 3 currently says "In either or both of the Run and Debug paths, click Browse" and it should probably say something like:
Under "URL or path to launch," click the Browse button for the entry that has bin-debug in the path
Other tha
...Copy link to clipboard
These directions are not clear. How do you set this up in Flash Builder 4.6? I cannot tell from these directions where it is talking about.
Other than that, I tried this and it worked OK for me.
Hope this helps,
Randy Nielsen
Senior Content and Community Manager
Adobe Systems Incorporated
thanks for elaboration
