What is wrong with this function? I am trying to create a
user login that
checks to make sure the user is in the database first, then
check the active
level. If the level is 1 then set sessions and redirect, if 2
then redirect
to the login page and send a URL variable of
account=suspended, if 0 then
redirect to the login page sending a URL variable of
account=inactive, etc.
I want to query the db first to see if the user is in the
datasbase. If yes,
then check the active number. I am getting this error in the
conditional
statement to check the 'active' column.
'You have attempted to dereference a scalar variable of type
class
java.lang.String as a structure with members'
What am I missing?
<cffunction name="UserLogin" access="remote"
returntype="void">
<cfargument name="username" type="string"
required="yes">
<cfargument name="password" type="string"
required="yes">
<cfquery name="login" datasource="***">
Select username, password, priv FROM users_database
WHERE username='#arguments.username#' AND
password='#arguments.password#'
</cfquery>
<cfif login.recordcount NEQ 0>
<cfif login.active EQ 1>
<cflock scope="session" timeout="30" type="exclusive">
<cfset Session.MM_Username = #arguments.username#>
<cfset Session.SitePriv = #login.priv#>
</cflock>
<cflocation url="/clinic/contribute/main/index.cfm"
addtoken="no">
<cfelseif login.active EQ 0>
<cflocation
url="/clinic/contribute/index.cfm?account=inactive"
addtoken="no">
<cfelseif login.active EQ 2>
<cflocation
url="/clinic/contribute/index.cfm?account=suspended"
addtoken="no">
<cfelseif login.active EQ 3>
<cflocation
url="/clinic/contribute/index.cfm?account=banned"
addtoken="no">
</cfif>
<cfelse>
<cflocation
url="/clinic/contribute/index.cfm?login=failed" addtoken="no">
</cfif>
</cffunction>
