6 Replies Latest reply on Feb 28, 2012 11:03 AM by CoreTech::Chuck
    How to create gamma (midtone) changes with help Pixel Bender?
    IlyaMordasov
      I'd like to create Level correction with help Pixel Bender. I made correction for each channel (r, g, b), it works. But I don't know how to make correction for midtone for each one.
      Is there some formula or example?
      Unfortunately google hasn't got solution
      I use the next code for each channel, for instance, the red channel will be look like
      dst.r = ((dst.r-red[0])/(red[1]-red[0])-rgb[1]-rgb[0]), where red[n], rgb[n] are the values which can be changed by user
        • 1. Re: How to create gamma (midtone) changes with help Pixel Bender?
          CoreTech::Chuck
          I'm not sure I'm understanding exactly what you're wanting.  There is a gamma tutorial with some glsl shaders at:
          http://www.geeks3d.com/20101001/tutorial-gamma-correction-a-story-of-linearity/
          A PixelBender shader for the channel by channel gamma is:
          <languageVersion : 1.0;>
          kernel channelByChannelGamma
          <   namespace : "cfr";
              vendor : "AIF";
              version : 1;
              input image4 src;
              output pixel4 dst;
              parameter float3 gammaRGB <defaultValue:float3(1.0, 1.0, 1.0);>;
              void
              evaluatePixel()
                  dst = sampleNearest(src,outCoord());
                  dst.rgb = pow(dst.rgb, 1.0 / gammaRGB);
          • 2. Re: How to create gamma (midtone) changes with help Pixel Bender?
            CoreTech::Chuck Newcomer
            Please let me know if I'm misunderstanding what you're trying to do here.
            • 3. Re: How to create gamma (midtone) changes with help Pixel Bender?
              IlyaMordasov Newcomer
              i'm not sure it's what i need. It changes rgb gamma and i need change gamma for each channel (like in photoshop).
              i posted screen shot what i looking for
              • 4. Re: How to create gamma (midtone) changes with help Pixel Bender?
                gammaRGB is a float3.  If you wanted to alter the gamma for G and leave the others unchanged, you can set that parameter to (1.0, greenGamma, 1.0).  The pow function and the 1.0 divide in the kernel are componentwise.  This line instead would have been equivalent, but does make the intention clearer:
                        dst.rgb = pow(dst.rgb, float3(1.0, 1.0, 1.0) / gammaRGB);
                Most of the intrinsic functions will return vectors if their operands are vectors.  Intrinsitcs like dot, any, and all, which specifically reduce a vector input to a scalar output, are the exceptions.
                1 person found this helpful
                • 5. Re: How to create gamma (midtone) changes with help Pixel Bender?
                  thanks for your reply! so, if i wanna change gamma for each channel separately i have to change your code so:
                  dst.rgb = pow(dst.rgb, float3(red[1], green[1], blue[1])/gammaRGB)
                  where red[1], green[1], blue[1] are the parameters of gamma
                  i compared the result which i've got and it's different from photoshop's
                  so, now my code looks like this
                      parameter float3 red
                          minValue: float3(0.0,0.0,1.0);
                          maxValue: float3(1.0,1.0,1.0);
                          defaultValue: float3(0.0,1.0,1.0);
                      parameter float3 green
                          minValue: float3(0.0,0.0,0.0);
                      parameter float3 blue
                      parameter float3 RGB
                          defaultValue: float3(0.0,1.0, 1.0);
                      input image4 src;
                      output pixel4 dst;
                      void
                      evaluatePixel()
                          pixel4 p = sampleNearest(src,outCoord());
                          float rgbdiff = RGB[2] - RGB[0];
                          p.r = ( (p.r - red[0])/(red[2] - red[0]) - RGB[0])/rgbdiff;
                          p.g = ( (p.g - green[0])/(green[2] - green[0]) - RGB[0])/rgbdiff;
                          p.b = ( (p.b - blue[0])/(blue[2] - blue[0]) - RGB[0])/rgbdiff;
                          p.rgb = pow(p.rgb, float3(red[1], green[1], blue[1]) / RGB[1]);
                          dst = p;
                  upd: i tried to apply this filter again and it seems to me it works! Thank you very much for your correct answer. Maybe you know how to use photoshop's 'output panel', this parameter increases/decreases values of channel. Photoshop has this parameter in the bottom of level's panel.
                  • 6. Re: How to create gamma (midtone) changes with help Pixel Bender?
                    I'm glad I was able to help.  I'm not certain what the exact formula the Photoshop team is using, so I was going on one in the gamma tutorial website I was pointed out earlier in this thread.  That seemed to follow the standard gamma formulation I've seen on wiki and in the CG texts I have in my office.
                    I did have a look at the panel you suggested.  I don't think I've used that one before, so thanks for the pointer.
                    Best,
                    Chuck.
