8 Replies Latest reply: Mar 1, 2012 1:42 AM by Manan Joshi RSS
    SDK newby, Building my first sample – no go...
    romanobstuder
      Hi all
      I would like to get into building ID extensions.
      I am currently trying to work through the "getting-started.pdf".
      My Mac and tools.
      iMac with OS 10.7.3
      InDesign CS 5.5 (Version 7.5)
      Xcode Version 4.2.1 Build 4D502
      I installed "Adobe InDesign CS5.5 SDK" inside my "Applications" Folder
      I follow the instructions in the "getting-started":
      Start by double-clicking on any SDK sample project.
      This boots Xcode...
      From then on I can not make any sense of the instructions, ie
      1. Use the Active Target drop-down list on the top left corner of the project window to make sure you are
      building the desired target.
      2. Choose Build > Rebuild ### to do a clean rebuild of the project.
      I then tried the Terminal approach to things...
      The xcodebuild utility is useful for building XCode projects on the command line. For example, the
      following builds the release target of the Basic dialog project:
      xcodebuild -project BasicDialog.sdk.xcodeproj -target Release build
      Yes I did cd myself into the correct folder first. But this made no difference.
      Also:
      We recommend that you have both the debug and
      release applications. The debug application is
      instrumented to detect bugs and is essential to
      successful plug-in development.
      What does that mean? Is there a different ID 5.5 that I need? Where do I get this?
      Thank you for any hints
      Romano
        • 1. Re: SDK newby, Building my first sample – no go...
          Manan Joshi Community Member
          Romano,
          Adobe recommends XCode 3.1.3 for Indesign plugin devlopment. I would recommend you go through the dev environment specs by Adobe before starting the development.
          Secondly could you specify what error are you getting while trying to build from the XCode IDE.
          And regarding the Debug and Release versions of Indesign, these are two versions of Indesign. Development is recommended on Debug version as it provides more debugging info and support that helps the developer. But it is difficult to get hold of the debug version, i suppose you need to a solution partner to adobe for getting it. However you can develop on release version too, you just need to create the release build of your project, though surely you will lack debugging features in this build.
          Manan Joshi
            - Efficient InDesign Solutions -
          MetaDesign Solutions
          http://metadesignsolutions.com/services/indesign-development.php
          • 2. Re: SDK newby, Building my first sample – no go...
            romanobstuder Community Member
            Required component Notes
            Intel® processor
            Mac OS 10.5 or later
            Xcode 3.1 Download this from
            http://developer.apple.com/technologies/xcode.html
            Hi Manan
            Thank you for your response.
            I realize you may only have some of the answers to this, so the following questions are still to anybody that can help or an Adobe Sysop of there is any in this forum.
            The "getting-started" states Xcode 3.1, the link points at apples download page and that is the most current version of Xcode.
            Not sure what that means, 3.1 just the minimum or the only one working?
            Also where can I get 3.1 if I need it.
            Solution Partner for Adobe:
            You mean I need to become a Solution Partner or ask a Solution Partner to "lend" me a copy?
            I will keep trying...
            (Will also post the error codes a bit later...)
            Thank you Manan and all the best
            Romano
            • 3. Re: SDK newby, Building my first sample – no go...
              Here is the dump Terminal.
              Not sure if this means anything to anybody...
              Romano
              studer-imac:prj studer$
              studer-imac:prj studer$ pwd
              /Applications/Adobe InDesign CS5.5 SDK/build/mac/prj
              studer-imac:prj studer$ xcodebuild -project BasicDialog.sdk.xcodeproj -target Release build
              === BUILD NATIVE TARGET Release OF PROJECT BasicDialog.sdk WITH THE DEFAULT CONFIGURATION (Default) ===
              2012-03-01 12:25:40.577 xcodebuild[1446:3e03] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
              2012-03-01 12:25:40.578 xcodebuild[1446:3e03] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
              Check dependencies
              Preprocess build/BasicDialog.sdk.build/Default/Release.build/Preprocessed-Info.plist ../../../source/sdksamples/common/Info.plist
                  cd "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj"
                  /Developer/usr/bin/gcc -E -P -x c -Wno-trigraphs ../../../source/sdksamples/common/Info.plist "-F/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK" -o "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Preprocessed-Info.pli st"
              error: can't exec '/Developer/usr/bin/gcc' (No such file or directory)
              PhaseScriptExecution "Run Script" build/BasicDialog.sdk.build/Default/Release.build/Script-D8C837AA0F8EC49400085251.sh
                  setenv ACTION build
                  setenv ALTERNATE_GROUP studer
                  setenv ALTERNATE_MODE u+w,go-w,a+rX
                  setenv ALTERNATE_OWNER studer
                  setenv ALWAYS_REZ YES
                  setenv ALWAYS_SEARCH_USER_PATHS YES
                  setenv APPLE_INTERNAL_DEVELOPER_DIR /AppleInternal/Developer
                  setenv APPLE_INTERNAL_DIR /AppleInternal
                  setenv APPLE_INTERNAL_DOCUMENTATION_DIR /AppleInternal/Documentation
                  setenv APPLE_INTERNAL_LIBRARY_DIR /AppleInternal/Library
                  setenv APPLE_INTERNAL_TOOLS /AppleInternal/Developer/Tools
                  setenv APPLY_RULES_IN_COPY_FILES NO
                  setenv ARCHS i386
                  setenv ARCHS_STANDARD_32_64_BIT "x86_64 i386 ppc"
                  setenv ARCHS_STANDARD_32_BIT "i386 ppc"
                  setenv ARCHS_STANDARD_64_BIT x86_64
                  setenv ASL_HEADER_SEARCH_PATHS "../../../external/asl/boost_libraries/ ../../../external/asl/intel_tbb_libraries/include/ ../../../external/asl/adobe_source_libraries/"
                  setenv BIB_THROW BIB_NO_THROW
                  setenv BUILD_COMPONENTS "headers build"
                  setenv BUILD_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build"
                  setenv BUILD_ROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build"
                  setenv BUILD_STYLE Default
                  setenv BUILD_VARIANTS normal
                  setenv BUILT_APPLICATION_DIR ../../../build/mac/Release/packagefolder/contents/macos/
                  setenv BUILT_PRODUCTS_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK"
                  setenv CACHE_ROOT /var/folders/8s/vxz9psl48xl5j0006s6r9qlh0000gp/C/com.apple.Xcode.502
                  setenv CCHROOT /var/folders/8s/vxz9psl48xl5j0006s6r9qlh0000gp/C/com.apple.Xcode.502
                  setenv CHMOD /bin/chmod
                  setenv CHOWN /usr/sbin/chown
                  setenv CLASS_FILE_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/JavaClasses"
                  setenv CLEAN_PRECOMPS YES
                  setenv CLONE_HEADERS NO
                  setenv CODESIGNING_FOLDER_PATH "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK/BasicDialog.sdk.InDesignPlugin/Versions/A"
                  setenv CODE_SIGNING_ALLOWED YES
                  setenv COMMAND_MODE legacy
                  setenv COMPOSITE_SDK_DIRS /var/folders/8s/vxz9psl48xl5j0006s6r9qlh0000gp/C/com.apple.Xcode.502/CompositeSDKs
                  setenv CONFIGURATION Default
                  setenv CONFIGURATION_BUILD_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK"
                  setenv CONFIGURATION_TEMP_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default"
                  setenv CONTENTS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A
                  setenv COPYING_PRESERVES_HFS_DATA NO
                  setenv COPY_PHASE_STRIP YES
                  setenv COPY_RESOURCES_FROM_STATIC_FRAMEWORKS YES
                  setenv CP /bin/cp
                  setenv CURRENT_ARCH i386
                  setenv CURRENT_VARIANT normal
                  setenv CURRENT_VERSION Current
                  setenv DEAD_CODE_STRIPPING YES
                  setenv DEBUGGING_SYMBOLS YES
                  setenv DEBUG_INFORMATION_FORMAT dwarf
                  setenv DEPLOYMENT_LOCATION NO
                  setenv DEPLOYMENT_POSTPROCESSING NO
                  setenv DERIVED_FILES_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/DerivedSources"
                  setenv DERIVED_FILE_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/DerivedSources"
                  setenv DERIVED_SOURCES_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/DerivedSources"
                  setenv DEVELOPER_APPLICATIONS_DIR /Developer/Applications
                  setenv DEVELOPER_BIN_DIR /Developer/usr/bin
                  setenv DEVELOPER_DIR /Developer
                  setenv DEVELOPER_FRAMEWORKS_DIR /Developer/Library/Frameworks
                  setenv DEVELOPER_FRAMEWORKS_DIR_QUOTED "\"/Developer/Library/Frameworks\""
                  setenv DEVELOPER_LIBRARY_DIR /Developer/Library
                  setenv DEVELOPER_SDK_DIR /Developer/SDKs
                  setenv DEVELOPER_TOOLS_DIR /Developer/Tools
                  setenv DEVELOPER_USR_DIR /Developer/usr
                  setenv DEVELOPMENT_LANGUAGE English
                  setenv DOCUMENTATION_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/English.lproj/Documentation
                  setenv DO_HEADER_SCANNING_IN_JAM NO
                  setenv DSTROOT /tmp/BasicDialog.sdk.dst
                  setenv DWARF_DSYM_FILE_NAME BasicDialog.sdk.InDesignPlugin.dSYM
                  setenv DWARF_DSYM_FOLDER_PATH "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK"
                  setenv DYLIB_INSTALL_NAME_BASE ./
                  setenv ENABLE_HEADER_DEPENDENCIES YES
                  setenv ENABLE_OPENMP_SUPPORT NO
                  setenv EXCLUDED_INSTALLSRC_SUBDIRECTORY_PATTERNS ".svn CVS"
                  setenv EXCLUDED_RECURSIVE_SEARCH_PATH_SUBDIRECTORIES "*.nib *.lproj *.framework *.gch (*) CVS .svn *.xcodeproj *.xcode *.pbproj *.pbxproj"
                  setenv EXECUTABLES_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/English.lproj
                  setenv EXECUTABLE_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A
                  setenv EXECUTABLE_NAME BasicDialog.sdk
                  setenv EXECUTABLE_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/BasicDialog.sdk
                  setenv FILE_LIST "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Objects/LinkFileList"
                  setenv FIXED_FILES_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/FixedFiles"
                  setenv FRAMEWORKS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Frameworks
                  setenv FRAMEWORK_FLAG_PREFIX -framework
                  setenv FRAMEWORK_SEARCH_PATHS "\"/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK\"  ../../../build/mac/release/packagefolder/contents/macos ../../../build/mac/release/packagefolder/contents/Frameworks"
                  setenv FRAMEWORK_VERSION A
                  setenv FULL_PRODUCT_NAME BasicDialog.sdk.InDesignPlugin
                  setenv GCC3_VERSION 3.3
                  setenv GCC_ENABLE_CPP_EXCEPTIONS YES
                  setenv GCC_ENABLE_CPP_RTTI YES
                  setenv GCC_ENABLE_SYMBOL_SEPARATION YES
                  setenv GCC_GENERATE_DEBUGGING_SYMBOLS YES
                  setenv GCC_INCREASE_PRECOMPILED_HEADER_SHARING YES
                  setenv GCC_INLINES_ARE_PRIVATE_EXTERN YES
                  setenv GCC_INPUT_FILETYPE sourcecode.cpp.cpp
                  setenv GCC_MODEL_TUNING G5
                  setenv GCC_OPTIMIZATION_LEVEL 3
                  setenv GCC_PFE_FILE_C_DIALECTS "c objective-c c++ objective-c++"
                  setenv GCC_PRECOMPILE_PREFIX_HEADER YES
                  setenv GCC_PREFIX_HEADER ../../../source/precomp/gcc/PluginPrefix.pch
                  setenv GCC_PREPROCESSOR_DEFINITIONS " MACINTOSH MACOSX_SDKVERSION=1050 BIB_NO_THROW NDEBUG"
                  setenv GCC_SYMBOLS_PRIVATE_EXTERN YES
                  setenv GCC_THREADSAFE_STATICS NO
                  setenv GCC_TREAT_WARNINGS_AS_ERRORS YES
                  setenv GCC_VERSION 4.0
                  setenv GCC_VERSION_IDENTIFIER __0
                  setenv GCC_WARN_ABOUT_DEPRECATED_FUNCTIONS NO
                  setenv GCC_WARN_ABOUT_MISSING_PROTOTYPES YES
                  setenv GCC_WARN_ABOUT_RETURN_TYPE YES
                  setenv GCC_WARN_CHECK_SWITCH_STATEMENTS NO
                  setenv GCC_WARN_HIDDEN_VIRTUAL_FUNCTIONS YES
                  setenv GCC_WARN_INHIBIT_ALL_WARNINGS NO
                  setenv GCC_WARN_INITIALIZER_NOT_FULLY_BRACKETED YES
                  setenv GCC_WARN_MISSING_PARENTHESES YES
                  setenv GCC_WARN_NON_VIRTUAL_DESTRUCTOR NO
                  setenv GCC_WARN_SHADOW YES
                  setenv GCC_WARN_UNUSED_FUNCTION YES
                  setenv GCC_WARN_UNUSED_LABEL YES
                  setenv GCC_WARN_UNUSED_PARAMETER YES
                  setenv GCC_WARN_UNUSED_VALUE YES
                  setenv GCC_WARN_UNUSED_VARIABLE NO
                  setenv GENERATE_MASTER_OBJECT_FILE NO
                  setenv GENERATE_PKGINFO_FILE NO
                  setenv GENERATE_PROFILING_CODE NO
                  setenv GID 502
                  setenv GROUP studer
                  setenv HEADERMAP_INCLUDES_FLAT_ENTRIES_FOR_TARGET_BEING_BUILT YES
                  setenv HEADERMAP_INCLUDES_FRAMEWORK_ENTRIES_FOR_ALL_PRODUCT_TYPES YES
                  setenv HEADERMAP_INCLUDES_NONPUBLIC_NONPRIVATE_HEADERS YES
                  setenv HEADERMAP_INCLUDES_PROJECT_HEADERS YES
                  setenv HEADER_SEARCH_PATHS "\"/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK/include\" /Developer/SDKs/MacOSX10.5.sdk/Developer/Headers/FlatCarbon ../../../source/precomp/common ../../../source/precomp/msvc ../../../source/precomp/gcc ../../../source/public/includes  ../../../source/public/interfaces/architecture ../../../source/public/interfaces/utils ../../../source/public/interfaces/xmedia ../../../source/public/libs/widgetbin/includes ../../../source/open/includes/** ../../../source/open/interfaces/** ../../../source/open/libs/widgetbin/includes ../../../external/asl/boost_libraries/ ../../../external/asl/intel_tbb_libraries/include/ ../../../external/asl/adobe_source_libraries/ ../../../external/afl/includes ../../../source/precomp/msvc ../../../source/public/interfaces/xmedia ../../../source/public/interfaces/ui ../../../source/public/interfaces/tables ../../../source/public/interfaces/text ../../../source/public/interfaces/graphics ../../../source/public/components/widgetbin/includes ../../../source/public/interfaces/workgroup ../../../source/public/interfaces/interactive ../../../source/public/interfaces/interactive/ui ../../../source/public/interfaces/colormgmt ../../../source/public/interfaces/utils ../../../source/public/interfaces/incopy ../../../source/public/interfaces/layout ../../../source/public/interfaces/architecture ../../../source/public/interfaces/cjk ../../../source/public/facades/graphics ../../../source/public/facades/text ../../../source/public/facades/layout ../../../source/precomp/common ../../../source/public/includes ../../../source/public/components/publiclib/plugins ../../../source/public/components/publiclib/files ../../../source/public/components/publiclib/objectmodel ../../../source/sdksamples/common ../../../external/afl/includes"
                  setenv ICONV /usr/bin/iconv
                  setenv IC_CREATOR "\"InCp\""
                  setenv ID_ALLPUBLIC_HEADER_SEARCH_PATHS "../../../source/precomp/common ../../../source/precomp/msvc ../../../source/precomp/gcc ../../../source/public/includes ../../../source/public/interfaces/** ../../../source/public/libs/widgetbin/includes"
                  setenv ID_APPLICATION_TYPE "\"APPL\""
                  setenv ID_BUILD_CONFIG_COMMON YES
                  setenv ID_BUILD_CONFIG_COMMON_RELEASE YES
                  setenv ID_BUILD_CONFIG_PLUGIN_RELEASE YES
                  setenv ID_BUILD_CONFIG_PLUGIN_SDK YES
                  setenv ID_BUILT_SDK_SAMPLES_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK"
                  setenv ID_COMMON_HEADER_SEARCH_PATHS "/Developer/SDKs/MacOSX10.5.sdk/Developer/Headers/FlatCarbon ../../../source/precomp/common ../../../source/precomp/msvc ../../../source/precomp/gcc ../../../source/public/includes  ../../../source/public/interfaces/architecture ../../../source/public/interfaces/utils ../../../source/public/interfaces/xmedia ../../../source/public/libs/widgetbin/includes ../../../source/open/includes/** ../../../source/open/interfaces/** ../../../source/open/libs/widgetbin/includes ../../../external/asl/boost_libraries/ ../../../external/asl/intel_tbb_libraries/include/ ../../../external/asl/adobe_source_libraries/"
                  setenv ID_COMMON_REZ_SEARCH_PATHS "/Developer/SDKs/MacOSX10.5.sdk/Developer/Headers/FlatCarbon ../../../source/precomp/common ../../../source/precomp/msvc ../../../source/public/includes"
                  setenv ID_CREATOR "\"InDn\""
                  setenv ID_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release"
                  setenv ID_FUTURE_VERSION_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/packagefolder/contents/macos/future version"
                  setenv ID_OPEN_HEADER_SEARCH_PATHS "../../../source/open/includes/** ../../../source/open/interfaces/** ../../../source/open/libs/widgetbin/includes"
                  setenv ID_PLUGINS_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/plug-ins"
                  setenv ID_PLUGIN_OPTIONAL_TYPE "\"InDa\""
                  setenv ID_PLUGIN_REQUIRED_TYPE "\"InDr\""
                  setenv ID_PLUGIN_SDK_TYPE "\"InD3\""
                  setenv ID_PRJ_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj"
                  setenv ID_PUBLIC_HEADER_SEARCH_PATHS "../../../source/precomp/common ../../../source/precomp/msvc ../../../source/precomp/gcc ../../../source/public/includes  ../../../source/public/interfaces/architecture ../../../source/public/interfaces/utils ../../../source/public/interfaces/xmedia ../../../source/public/libs/widgetbin/includes"
                  setenv ID_REQUIRED_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/packagefolder/contents/macos/required"
                  setenv ID_SDK_ROOT ../../..
                  setenv ID_SHARED_PRECOMPS_ROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/SharedPrecompiledHeaders"
                  setenv ID_TESTING_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/packagefolder/contents/macos/testing"
                  setenv ID_TOOLS_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/tools"
                  setenv INFOPLISTSTRINGS_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/English.lproj/InfoPlist.strings
                  setenv INFOPLIST_EXPAND_BUILD_SETTINGS YES
                  setenv INFOPLIST_FILE ../../../source/sdksamples/common/Info.plist
                  setenv INFOPLIST_OUTPUT_FORMAT same-as-input
                  setenv INFOPLIST_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/Info.plist
                  setenv INFOPLIST_PREPROCESS YES
                  setenv INSTALL_DIR /tmp/BasicDialog.sdk.dst./
                  setenv INSTALL_GROUP studer
                  setenv INSTALL_MODE_FLAG u+w,go-w,a+rX
                  setenv INSTALL_OWNER studer
                  setenv INSTALL_PATH ./
                  setenv INSTALL_ROOT /tmp/BasicDialog.sdk.dst
                  setenv JAVAC_DEFAULT_FLAGS "-J-Xms64m -J-XX:NewSize=4M -J-Dfile.encoding=UTF8"
                  setenv JAVA_APP_STUB /System/Library/Frameworks/JavaVM.framework/Resources/MacOS/JavaApplicationStub
                  setenv JAVA_ARCHIVE_CLASSES YES
                  setenv JAVA_ARCHIVE_TYPE JAR
                  setenv JAVA_COMPILER /usr/bin/javac
                  setenv JAVA_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/Java
                  setenv JAVA_FRAMEWORK_RESOURCES_DIRS Resources
                  setenv JAVA_JAR_FLAGS cv
                  setenv JAVA_SOURCE_SUBDIR .
                  setenv JAVA_USE_DEPENDENCIES YES
                  setenv JAVA_ZIP_FLAGS -urg
                  setenv JIKES_DEFAULT_FLAGS "+E +OLDCSO"
                  setenv KEEP_PRIVATE_EXTERNS NO
                  setenv LD_DYLIB_INSTALL_NAME ./BasicDialog.sdk.InDesignPlugin/Versions/A/BasicDialog.sdk
                  setenv LD_GENERATE_MAP_FILE NO
                  setenv LD_MAP_FILE_PATH "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/BasicDialog.sdk-LinkM ap-normal-i386.txt"
                  setenv LD_OPENMP_FLAGS -fopenmp
                  setenv LEX /Developer/usr/bin/lex
                  setenv LIBRARY_FLAG_NOSPACE YES
                  setenv LIBRARY_FLAG_PREFIX -l
                  setenv LIBRARY_SEARCH_PATHS "\"/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK\"  ../../../build/mac/release/packagefolder/contents/macos/libs"
                  setenv LINKER_DISPLAYS_MANGLED_NAMES NO
                  setenv LINK_FILE_LIST_normal_i386 "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Objects-normal/i386/B asicDialog.sdk.LinkFileList"
                  setenv LINK_WITH_STANDARD_LIBRARIES YES
                  setenv LOCALIZED_RESOURCES_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/English.lproj
                  setenv LOCAL_ADMIN_APPS_DIR /Applications/Utilities
                  setenv LOCAL_APPS_DIR /Applications
                  setenv LOCAL_DEVELOPER_DIR /Library/Developer
                  setenv LOCAL_LIBRARY_DIR /Library
                  setenv MACH_O_TYPE mh_dylib
                  setenv MACOSX_DEPLOYMENT_TARGET 10.5
                  setenv MACOSX_SDKVERSION 1050
                  setenv MAC_OS_X_VERSION_ACTUAL 1073
                  setenv MAC_OS_X_VERSION_MAJOR 1070
                  setenv MAC_OS_X_VERSION_MINOR 0703
                  setenv NATIVE_ARCH i386
                  setenv NATIVE_ARCH_32_BIT i386
                  setenv NATIVE_ARCH_64_BIT x86_64
                  setenv NATIVE_ARCH_ACTUAL x86_64
                  setenv NO_COMMON YES
                  setenv OBJECT_FILE_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Objects"
                  setenv OBJECT_FILE_DIR_normal "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Objects-normal"
                  setenv OBJROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build"
                  setenv ONLY_ACTIVE_ARCH NO
                  setenv ONLY_LINK_ESSENTIAL_SYMBOLS YES
                  setenv OPTIMIZATION_LEVEL 0
                  setenv OS MACOS
                  setenv OSAC /usr/bin/osacompile
                  setenv OS_HEADER_SEARCH_PATHS /Developer/SDKs/MacOSX10.5.sdk/Developer/Headers/FlatCarbon
                  setenv OTHER_LDFLAGS "-Wl,-executable_path -Wl,../../../build/mac/Release/packagefolder/contents/macos/"
                  setenv OTHER_REZFLAGS "-d __GNUC__ -d MACINTOSH"
                  setenv PACKAGE_TYPE com.apple.package-type.wrapper.framework
                  setenv PASCAL_STRINGS YES
                  setenv PATH_PREFIXES_EXCLUDED_FROM_HEADER_DEPENDENCIES "/usr/include /usr/local/include /System/Library/Frameworks /System/Library/PrivateFrameworks /Developer/Headers /Developer/SDKs /Developer/Platforms"
                  setenv PBDEVELOPMENTPLIST_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/pbdevelopment.plist
                  setenv PER_ARCH_CFLAGS_i386 -DMACTEL_SKIP
                  setenv PFE_FILE_C_DIALECTS c++
                  setenv PKGINFO_FILE_PATH "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/PkgInfo"
                  setenv PKGINFO_PATH BasicDialog.sdk.InDesignPlugin/PkgInfo
                  setenv PLATFORM_DEVELOPER_APPLICATIONS_DIR /Developer/Applications
                  setenv PLATFORM_DEVELOPER_BIN_DIR /Developer/usr/bin
                  setenv PLATFORM_DEVELOPER_LIBRARY_DIR /Developer/Library
                  setenv PLATFORM_DEVELOPER_SDK_DIR /Developer/SDKs
                  setenv PLATFORM_DEVELOPER_TOOLS_DIR /Developer/Tools
                  setenv PLATFORM_DEVELOPER_USR_DIR /Developer/usr
                  setenv PLATFORM_NAME macosx
                  setenv PLC_GENERATE_PKGINFO_FILE YES
                  setenv PLC_INCLUDES "/Developer/Headers/FlatCarbon ../../../source/precomp/** ../../../source/public/includes ../../../source/components/documentui ../../../source/components/documentactions ../../../source/application/shared ../../../source/components/s4sp/control/includes ../../../source/components/kfkerning/hzincludes ../../../source/components/filters/pngfilter ../../../external/application\\ icons ../../../external/workflow\\ icons"
                  setenv PLC_OUTPUT_CREATOR InDn
                  setenv PLC_OUTPUT_TYPE InDa
                  setenv PLIST_FILE_OUTPUT_FORMAT same-as-input
                  setenv PLUGINS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources
                  setenv PREBINDING NO
                  setenv PRECOMPS_INCLUDE_HEADERS_FROM_BUILT_PRODUCTS_DIR YES
                  setenv PRECOMP_DESTINATION_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/PrefixHeaders"
                  setenv PRESERVE_DEAD_CODE_INITS_AND_TERMS YES
                  setenv PRIVATE_HEADERS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/PrivateHeaders
                  setenv PRODUCT_NAME BasicDialog.sdk
                  setenv PRODUCT_SETTINGS_PATH "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../../../source/sdksamples/common/Info.plist"
                  setenv PRODUCT_TYPE com.apple.product-type.framework
                  setenv PROFILING_CODE NO
                  setenv PROJECT BasicDialog.sdk
                  setenv PROJECT_DERIVED_FILE_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/DerivedSources"
                  setenv PROJECT_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj"
                  setenv PROJECT_FILE_PATH "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/BasicDialog.sdk.xcodeproj"
                  setenv PROJECT_NAME BasicDialog.sdk
                  setenv PROJECT_TEMP_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build"
                  setenv PUBLIC_HEADERS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Headers
                  setenv RECURSIVE_SEARCH_PATHS_FOLLOW_SYMLINKS YES
                  setenv REMOVE_CVS_FROM_RESOURCES YES
                  setenv REMOVE_SVN_FROM_RESOURCES YES
                  setenv REZ_COLLECTOR_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/ResourceManagerResour ces"
                  setenv REZ_OBJECTS_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/ResourceManagerResour ces/Objects"
                  setenv REZ_SEARCH_PATHS "\"/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK\" /Developer/SDKs/MacOSX10.5.sdk/Developer/Headers/FlatCarbon ../../../source/precomp/common ../../../source/precomp/msvc ../../../source/public/includes ../../../external/palettes ../../../external/workflow icons"
                  setenv RUN_CLANG_STATIC_ANALYZER YES
                  setenv SCAN_ALL_SOURCE_FILES_FOR_INCLUDES YES
                  setenv SCRIPTS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/Scripts
                  setenv SCRIPT_INPUT_FILE_COUNT 0
                  setenv SCRIPT_OUTPUT_FILE_COUNT 0
                  setenv SDKROOT /Developer/SDKs/MacOSX10.5.sdk
                  setenv SDK_DIR /Developer/SDKs/MacOSX10.5.sdk
                  setenv SDK_NAME macosx10.5
                  setenv SED /usr/bin/sed
                  setenv SEPARATE_STRIP NO
                  setenv SEPARATE_SYMBOL_EDIT NO
                  setenv SET_DIR_MODE_OWNER_GROUP YES
                  setenv SET_FILE_MODE_OWNER_GROUP NO
                  setenv SHARED_DERIVED_FILE_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK/DerivedSources"
                  setenv SHARED_FRAMEWORKS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/SharedFrameworks
                  setenv SHARED_PRECOMPS_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/SharedPrecompiledHeaders/Release"
                  setenv SHARED_SUPPORT_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources
                  setenv SKIP_INSTALL YES
                  setenv SOURCE_ROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj"
                  setenv SRCROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj"
                  setenv STANDARD_C_PLUS_PLUS_LIBRARY_TYPE dynamic
                  setenv STRINGS_FILE_OUTPUT_ENCODING UTF-16
                  setenv STRIP_INSTALLED_PRODUCT YES
                  setenv STRIP_STYLE debugging
                  setenv SYMBOL_REPOSITORY_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/SymbolRepositories"
                  setenv SYMROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build"
                  setenv SYSTEM_ADMIN_APPS_DIR /Applications/Utilities
                  setenv SYSTEM_APPS_DIR /Applications
                  setenv SYSTEM_CORE_SERVICES_DIR /System/Library/CoreServices
                  setenv SYSTEM_DEMOS_DIR /Applications/Extras
                  setenv SYSTEM_DEVELOPER_APPS_DIR /Developer/Applications
                  setenv SYSTEM_DEVELOPER_BIN_DIR /Developer/usr/bin
                  setenv SYSTEM_DEVELOPER_DEMOS_DIR "/Developer/Applications/Utilities/Built Examples"
                  setenv SYSTEM_DEVELOPER_DIR /Developer
                  setenv SYSTEM_DEVELOPER_DOC_DIR "/Developer/ADC Reference Library"
                  setenv SYSTEM_DEVELOPER_GRAPHICS_TOOLS_DIR "/Developer/Applications/Graphics Tools"
                  setenv SYSTEM_DEVELOPER_JAVA_TOOLS_DIR "/Developer/Applications/Java Tools"
                  setenv SYSTEM_DEVELOPER_PERFORMANCE_TOOLS_DIR "/Developer/Applications/Performance Tools"
                  setenv SYSTEM_DEVELOPER_RELEASENOTES_DIR "/Developer/ADC Reference Library/releasenotes"
                  setenv SYSTEM_DEVELOPER_TOOLS /Developer/Tools
                  setenv SYSTEM_DEVELOPER_TOOLS_DOC_DIR "/Developer/ADC Reference Library/documentation/DeveloperTools"
                  setenv SYSTEM_DEVELOPER_TOOLS_RELEASENOTES_DIR "/Developer/ADC Reference Library/releasenotes/DeveloperTools"
                  setenv SYSTEM_DEVELOPER_USR_DIR /Developer/usr
                  setenv SYSTEM_DEVELOPER_UTILITIES_DIR /Developer/Applications/Utilities
                  setenv SYSTEM_DOCUMENTATION_DIR /Library/Documentation
                  setenv SYSTEM_LIBRARY_DIR /System/Library
                  setenv TARGETNAME Release
                  setenv TARGET_BUILD_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/../Release/SDK"
                  setenv TARGET_NAME Release
                  setenv TARGET_TEMP_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build"
                  setenv TEMP_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build"
                  setenv TEMP_FILES_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build"
                  setenv TEMP_FILE_DIR "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build"
                  setenv TEMP_ROOT "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build"
                  setenv UID 502
                  setenv UNLOCALIZED_RESOURCES_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources
                  setenv UNSTRIPPED_PRODUCT NO
                  setenv USER studer
                  setenv USER_APPS_DIR /Users/studer/Applications
                  setenv USER_LIBRARY_DIR /Users/studer/Library
                  setenv USE_DYNAMIC_NO_PIC YES
                  setenv USE_HEADERMAP YES
                  setenv USE_HEADER_SYMLINKS NO
                  setenv VALIDATE_PRODUCT NO
                  setenv VALID_ARCHS "i386 x86_64"
                  setenv VERBOSE_PBXCP NO
                  setenv VERSIONPLIST_PATH BasicDialog.sdk.InDesignPlugin/Versions/A/Resources/version.plist
                  setenv VERSIONS_FOLDER_PATH BasicDialog.sdk.InDesignPlugin/Versions
                  setenv VERSION_INFO_BUILDER studer
                  setenv VERSION_INFO_FILE BasicDialog.sdk_vers.c
                  setenv VERSION_INFO_STRING "\"@(#)PROGRAM:BasicDialog.sdk  PROJECT:BasicDialog.sdk-\""
                  setenv WARNING_CFLAGS "-Wchar-subscripts -Wimplicit -Wsequence-point -Winit-self -Wmissing-field-initializers -Wpointer-arith -Wcast-align -Wpacked"
                  setenv WRAPPER_EXTENSION InDesignPlugin
                  setenv WRAPPER_NAME BasicDialog.sdk.InDesignPlugin
                  setenv WRAPPER_SUFFIX .InDesignPlugin
                  setenv XCODE_APP_SUPPORT_DIR /Developer/Library/Xcode
                  setenv XCODE_VERSION_ACTUAL 0323
                  setenv XCODE_VERSION_MAJOR 0300
                  setenv XCODE_VERSION_MINOR 0320
                  setenv YACC /Developer/usr/bin/yacc
                  /bin/sh -c "\"/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Script-D8C837AA0F8EC4 9400085251.sh\""
              ** BUILD FAILED **
              The following build commands failed:
              Release:
                        Preprocess "/Applications/Adobe InDesign CS5.5 SDK/build/mac/prj/build/BasicDialog.sdk.build/Default/Release.build/Preprocessed-Info.pli st" ../../../source/sdksamples/common/Info.plist
              (1 failure)
              • 4. Re: SDK newby, Building my first sample – no go...
                I have now installed Xcode 3.2.3
                I am trying to compile a sample file and get this error:
                from the command line typing "gcc" does this:
                studer-imac:bin studer$ gcc
                i686-apple-darwin11-llvm-gcc-4.2: no input files
                from the command line typing "which gcc" does this:
                studer-imac:bin studer$ which gcc
                /usr/bin/gcc
                This tells me that the compiler is present...
                why would Xcode not find it?
                • 5. Re: SDK newby, Building my first sample – no go...
                  Hi Romano,
                  For details regarding getting the Debug version of Indesign you could refer to the link
                  "http://blogs.adobe.com/notesfrommnr/2005/08/heres_how_to_ge.html"
                  Manan Joshi
                  • 6. Re: SDK newby, Building my first sample – no go...
                    As far as i can make from the command prompt display and the error you are getting, you have your XCode installation wrong.
                    Because Indesign plugin projects require gcc 4.0, but the command prompt display shows the gcc version as 4.2, moreover the error you are getting says the absence of gcc at the location '/Developer/usr/bin/gcc'.
                    How did you install 3.2.3, did you install it after you installed Xcode 4. As far as i know you should first to install Xcode 3 and then install XCode4. I have installed it that way in my MAC and everything works fine the only difference is that i am on a Snow Leopard.
                    Hope this helps you.
                    Manan Joshi
                    • 7. Re: SDK newby, Building my first sample – no go...
                      When istalling Xcode 3 the installation gets placed on the hard drive in a folder called XCode3.2.3
                      When istalling Xcode 4 the installation gets placed on the hard drive in a folder called Developer
                      I tried to be very smart and renamed the folders into something that like XCode3_stuff and XCode4_Stuff...
                      big mistake....
                      Anyway all back to default and I can now compile!
                      Yahoo
                      Thanks Manan for hanging in there with me
                      Ciao
                      Romano
                      • 8. Re: SDK newby, Building my first sample – no go...
                        Good to know that you have finally got it up and working.
                        If the problem is resolved it's better you mark the question as answered to help others looking for a solution to the problem.
                        Manan Joshi
