Show 6 replies
1. Re: Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
John T Smith Feb 29, 2012 3:50 PM (in response to GianniQ)To burn dual layer you MUST right click the Encore icon and select Run as Administrator from the popup window... this is NOT the same as using an Administrator account
I think you can select to "always" Run as Administrator from that popup window
2. Re: Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
ram8kumar Feb 29, 2012 8:20 PM (in response to John T Smith)John is right. The dual layer DVD burning requires to Run the Encore as Admin even when you are logged in as admin.
-Ramesh.
3. Re: Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
John T Smith Mar 1, 2012 8:02 AM (in response to GianniQ)Right click the Encore icon on your desktop
Select Properties
Shortcut tab
Select Advanced
Click the Run as Admin option
Click OK
Click OK
4. Re: Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
GianniQ Mar 2, 2012 8:27 PM (in response to John T Smith)Thanks guys, it worked!!! Thank you!!
5. Re: Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
WingersMedia Apr 17, 2012 7:05 AM (in response to John T Smith)Thank you!! I had the same issues.
6. Re: Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
h wolfe iii Oct 29, 2014 5:21 PM (in response to GianniQ)Sir, I had this problem with a nearly 3 hour wedding I was building for a DVD+R DL and this info was
a life saver! Thank you!!
