1. Re: Flash CS 5.5 - loading recent item fails
John R Nyquist Feb 29, 2012 5:52 PM (in response to MT.Freelance)Did you find out how to fix this?
2. Re: Flash CS 5.5 - loading recent item fails
MT.Freelance Feb 29, 2012 6:05 PM (in response to John R Nyquist)No. while it is annoying, and rather pathetic, IMO, it is not a work stopping issue, so I doubt that the devs will spend time fixing wharever it is that is causing this...
3. Re: Flash CS 5.5 - loading recent item fails
John R Nyquist Feb 29, 2012 6:50 PM (in response to MT.Freelance)I just found out what was causing it (for me). If I have a Windows 7 drive mounted, I get that error. If I unmount, things are back to normal. The tip was it saying that it couldn't find the file starting with "/Volumes"
4. Re: Flash CS 5.5 - loading recent item fails
MT.Freelance Feb 29, 2012 7:01 PM (in response to John R Nyquist)Thanks for the tip.
Since I work in a network environment, I have several shares mounted. It
isn't practical to disconnect them all just to enable a recent flash file
to load.
If I was running Flash via Parallels, I could see this issue with more
charity but I am using the Mac Flash within the Mac OS, and it cannot
locate files it saves on the Mac desktop. I've set parallels to share the
Mac disks and desktop, however, so perhaps that is throwing a wrinkle that
Flash cannot parse.
In any case, thanks again for the response.
