1 Reply Latest reply: Mar 2, 2012 2:59 AM by Nitin Goel RSS
    FMIS 4.5 / publish mp4 file
    oeann Community Member
      Hello,
      Finally i have success install my FMIS but http not work but i use rtmp its ok for me.
      I test with my flash cs5.5 i can publish but i think the codes or something is wrong.
      Because i have copy my file to my pc and attempt to listen bad codec.
      And i cannot in flash listen with flvplayback.
      nc = new NetConnection();
      nc.addEventListener(NetStatusEvent.NET_STATUS, nc_netStatusHandler);
      nc.client = this;
      nc.connect("rtmp://xx.xx.xx.107:1935/test");
      publish_stream();
      function publish_stream(){
          ns = new NetStream(nc);
          ns.attachAudio(mic);
          ns.attachCamera(webcam);
          //On publish le stream
          var now:Date = new Date();
          fileName = now.valueOf().toString();
          fileName = "mp4:" + nid + "_" + fileName + ".mp4";
          ns.addEventListener(NetStatusEvent.NET_STATUS, recordStart);
          ns.publish(fileName, "record");
      the filename is for example: mp4:2800_1330525211890.mp4
      then i cannot listen my record directly in my pc
      and cannot listen in as3 with this code:
      flvPlayBack.source = "rtmp://xx.xx.xx.107:1935/test/" + fileName;
      flvPlayBack.play();
      i thinks that i have a problem during record
      can you help me with this?
