9 Replies Latest reply: Mar 7, 2012 2:53 AM by Silviu Vergoti RSS
    Can not resolve a multiname reference unambiguously- OSMF build from scratch
    venky_123
      Hi
      I am trying to build OSMF from scratch and I have been following the Building OSMF and OSMF based projects guide - http://osmf.org/dev/osmf/specpdfs/building-osmf.pdf
      I've been doing everything by the guide but when I try to compile the project, which is the unmodified trunk from SVN, I get the following error (see below). I did a fair bit of googling but to no avail. Please Help me out!
      This is my entire log on compilation-
      E:\OSMF\OSMF SVN\trunk>ant
      Buildfile: E:\OSMF\OSMF SVN\trunk\build.xml
      all:
      build:
      compile.osmf:
      clean-bin:
      build:
         [delete] Deleting: E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSMF-build-config.tm
      p.xml
           [copy] Copying 1 file to E:\OSMF\OSMF SVN\trunk\framework\OSMF
          [compc] Loading configuration file E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSM
      F-build-config.tmp.xml
          [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\M
      anifestParser.as: Error: Can not resolve a multiname reference unambiguously. or
      g.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools
      \sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base 64Decoder)
      ) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\o
      rg\osmf\utils\Base64Decoder.as) are available.
          [compc]
          [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\B
      ootstrapInfoParser.as: Error: Can not resolve a multiname reference unambiguousl
      y. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\build
      tools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses :Base64Dec
      oder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\O
      SMF\org\osmf\utils\Base64Decoder.as) are available.
          [compc]
      ediaParser.as: Error: Can not resolve a multiname reference unambiguously. org.o
      smf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools\sd
      ks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base64D ecoder)) a
      nd org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\
          [compc]
          [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\D
      RMAdditionalHeaderParser.as: Error: Can not resolve a multiname reference unambi
      guously. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk
      \buildtools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mC lasses:Bas
      e64Decoder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\frame
      work\OSMF\org\osmf\utils\Base64Decoder.as) are available.
          [compc]
          [compc]
      g.osmf.elements.f4mClasses:DateUtil (from E:\OSMF\OSMF SVN\trunk\buildtools\sdks
      \4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:DateUtil) ) and org.
      osmf.utils:DateUtil (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\utils\D
      ateUtil.as) are available.
          [compc]
          [compc]
          [compc]
          [compc]
      anifestParser.as(137): col: 26 Error: Access of undefined property DateUtil.
          [compc]
          [compc]                             manifest.startTime = DateUtil.parseW3CDT
      F(root.nmsp::startTime.text());
          [compc]                                                  ^
          [compc]
      anifestParser.as(680): col: 18 Error: Type was not found or was not a compile-ti
      me constant: Base64Decoder.
          [compc]
          [compc]                                     var decoder:Base64Decoder = new
      Base64Decoder();
          [compc]                                                 ^
          [compc]
      anifestParser.as(680): col: 38 Error: Call to a possibly undefined method Base64
      Decoder.
          [compc]
      Base64Decoder();
          [compc]
          [compc]
      ootstrapInfoParser.as(92): col: 17 Error: Type was not found or was not a compil
      e-time constant: Base64Decoder.
          [compc]
          [compc]                             var decoder:Base64Decoder = new Base64De
      coder();
          [compc]                                         ^
          [compc]
      ootstrapInfoParser.as(92): col: 37 Error: Call to a possibly undefined method Ba
      se64Decoder.
          [compc]
      coder();
          [compc]                                                             ^
          [compc]
      ediaParser.as(67): col: 16 Error: Type was not found or was not a compile-time c
          [compc]
          [compc]                     var decoder:Base64Decoder;
          [compc]                                 ^
          [compc]
      ediaParser.as(147): col: 19 Error: Call to a possibly undefined method Base64Dec
      oder.
          [compc]
          [compc]                             decoder = new Base64Decoder();
          [compc]                                           ^
          [compc]
      ediaParser.as(154): col: 19 Error: Call to a possibly undefined method Base64Dec
      oder.
          [compc]
          [compc]                                           ^
          [compc]
      ediaParser.as(187): col: 19 Error: Call to a possibly undefined method Base64Dec
      oder.
          [compc]
          [compc]                                           ^
          [compc]
      RMAdditionalHeaderParser.as(91): col: 17 Error: Type was not found or was not a
      compile-time constant: Base64Decoder.
          [compc]
      coder();
          [compc]                                         ^
          [compc]
      RMAdditionalHeaderParser.as(91): col: 37 Error: Call to a possibly undefined met
      hod Base64Decoder.
          [compc]
      coder();
          [compc]                                                             ^
          [compc]
      BUILD FAILED
      E:\OSMF\OSMF SVN\trunk\build.xml:15: The following error occurred while executin
      g this line:
      E:\OSMF\OSMF SVN\trunk\build.xml:22: The following error occurred while executin
      g this line:
      E:\OSMF\OSMF SVN\trunk\build.xml:53: The following error occurred while executin
      g this line:
      E:\OSMF\OSMF SVN\trunk\framework\OSMF\build.xml:14: The following error occurred
      while executing this line:
      E:\OSMF\OSMF SVN\trunk\buildtools\utils.xml:107: compc task failed
      Total time: 56 seconds
