After a couple of tries at modifying the stylesheet, here is
what ended up working:
I made a new project so I could modify the CSS without any
drastic results. I removed all of the generated kadov code and
saved the .css file. Then I went into Robo and used the built in
CSS editor to remove the Bullets1, Bullets2 and Numbers styles, and
then added them back in.
Not only did this make my test topics appear correctly, it
put the correct code into the .css file (for my lists, the styles
were entered as LI and not P). The original Robo 5 stylesheet didnt
have any entires for UL or OL. Using the editor in Robo to remove
and add my list elements put that in the sheet.
Everything looks great.
Thank you both, Leon and Peter.
