3 Replies Latest reply on Mar 5, 2012 9:32 AM by kdeemer
    Help Adding Menu Items to Bridge
    kdeemer
      I've created (modified) a couple of Bridge Scripts and finally have them working nicely. Now, I want to add a couple of Menu Commands to execute them. I tried modifying a script in the SDK, SnpAddMenuItem.jsx, which would work fine if I only had one Menu Item/Command. Here is what I have. I obviously don't understand the 'this' object or how to separate the Commands. Help much appreciated.
      function SnpAddMenuItem()
                this.requiredContext = "\tAdobe Bridge must be running.\n\tExecute against Bridge CS5 as the target.\n";
                this.menuID = "snpAddMenuItem";
                this.menuCommandID = "snpAddMenuItemSub";
                $.level = 1; // Debugging level
      SnpAddMenuItem.prototype.run = function()
                var retval = true;
                if(!this.canRun()) {
                          retval = false;
                          return retval;
          var newMenu = new MenuElement( "menu", "Scanning", "after Window", this.menuID );
          var stackCommand = new MenuElement( "command", "Gather NNYY Into Stacks", "at the end of " + this.menuID, this.menuCommandID );
          var maskCommand = new MenuElement( "command", "Process Stacks into Layers", "at the end of " + this.menuID, this.menuCommandID );
                stackCommand.onSelect = function()
                          var scriptFilePath = "~/Documents/Adobe Scripts/AutostackNNYY.jsx";
               var scriptFile = new File (scriptFilePath);
               $.evalFile( scriptFile );
          return retval;
                maskCommand.onSelect = function()
                          var scriptFilePath = "~/Documents/Adobe Scripts/StacksToLayers.jsx";
                return retval;
        Determines whether snippet can be run given current context.  The snippet
        fails if these preconditions are not met:
        <ul>
        <li> Must be running in Bridge
        <li> Must only be executed once in a session
        </ul>
        @return True if this snippet can run, false otherwise
        @type boolean
      SnpAddMenuItem.prototype.canRun = function()
                // Must run in Bridge
                if(BridgeTalk.appName == "bridge") {
                          // Stop the menu element from being added again if the snippet has already run
                          if((MenuElement.find(this.menuID)) && (MenuElement.find(this.menuCommandID)))
                                    $.writeln("Error:Menu element already exists!\nRestart Bridge to run this snippet again.");
                                    return false;
                          return true;
                // Fail if these preconditions are not met.
                // Bridge must be running,
                // The menu must not already exist.
                $.writeln("ERROR:: Cannot run SnpAddMenuItem");
                $.writeln(this.requiredContext);
                return false;
        "main program": construct an anonymous instance and run it,
        as long as we are not unit-testing this snippet.
      if(typeof(SnpAddMenuItem_unitTest ) == "undefined") {
                new SnpAddMenuItem().run();
