I would like to spell check the entire project at one time. According the Adobe Community Help for RH9, I should do as follows:
Open a topic in the Design Editor. Do one of the following:
Currently, I only have one choice in the Tools menu: Spell Check...F7 which checks only the active document.
Do I need an add-on or something?
Do you have RoboHelp set up to show all options or just the shortened menus? If the latter, click the button at the bottom of the menu.
You don't say what version of RoboHelp you are using. Make sure you back up the project first as there was a bug in RoboHelp 8 that was fixed in 801. If you have 8 without 802 you are living dangerously anyway. It's described in Using RoboHelp 8 on my site.
Thank you Peter. It was indeed the shortened menus—I should know better. BTW, I am using RH9.
