Locked
Error message when installing Flash Player
Feb 19, 2012 Feb 19, 2012
Help - anyone know why I am getting the MSIMG32.dill is either not designed to run on Windows or it contains an error.
Any help would greatly apprecated.
4.9K
Advisor , Mar 05, 2012 Mar 05, 2012
Download these two files:'
Windows 64-bit: http://download.macromedia.com/pub/flashplayer/current/uninstall_flash _player_64bit.exe
Flash Player for Internet Explorer
Exit browser and disconnect from the Internet.
Run uninstaller and reboot.
Delete the Flash folder in folders C:\Windows\System32\Macromed and C:\Windows\SysWOW64\Macromed.
Delete the Flash Player folder in %appdata%\Adobe and %appdata%\Macromedia.
Run installer.
Advisor ,
Hi  Tried this.  No luck - none repaired - non needed repair.  error is
install_flash_player_ax_64bit.exe – Bad Image
C:\Users\Mike\AppData\Local\Temp\MSIMG32.dll is either not designed to run on Windows or it contains an error.  Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
Error: general installation error
Can anyone help?
Advisor ,
Run installer.
THANK YOU, THANK YOU, THANK YOU!!!!!
The only minor hiccup with the instructions, was location of the appdata folders. I found them (on my machine) C:\Users\Mike\AppData\Roaming.
Also, don’t know if it made any difference, but I disconnected from the internet again after the reboot and before doing anything else – figured it couldn’t hurt.
Thank you every so much again.
Mike Novak
