3 Replies Latest reply: Mar 5, 2012 7:34 PM by kellisails RSS
    Can't make an incremental backup in PSE 10 Organizer
    TucsonJeff1 Community Member
      I don't understand why I can't make an incremental backup in PSE 10 Organizer. I made my first full backup to my external drive a week ago. Today I tried to make an incremental backup. After selecting Incremental Backup from the file menu, a new screen appears asking for the Backup Path, and so I entered (by selecting) the full path name on my external drive where I made my original backup. But, next, it wants to know the name of the "Previous Backup file." I have absolutely no idea what the program wants at this point. What particular file does it want me to enter as the "previous backup file"?? There are hundreds of files in my backup directory. The backup directly does have a file called "Backup.tly" which I entered, hoping that this is the file it wants, but then I get this error message: "I:\Pictures\Adobe\Backup.tly does not contain a backup set for the current catalog. Please locate the last backup you made for this catalog." What am I missing here?
      Many thanks for your help,
      Jeff
        • 1. Re: Can't make an incremental backup in PSE 10 Organizer
          99jon Community Member
          Hi Jeff
          Once you have a full back up you can make incremental back ups but you need to follow a set routine. It’s not very intuitive.
          Start by creating a new folder or label a new CD/DVD Disk - it’s best to use dates e.g. “PSE10 incr backup 2012-0104”
          Press Ctrl+B and check Incremental, then click Next
          Highlight your drive containing the last backup and click the bottom Browse button (previous back up file) then navigate to the TLY file and click open.
          Click the Browse button above and navigate to your new folder “PSE10 incr backup 2012-0104”
          Click Done.
          If your full backup originally contained 500 images, the incremental backup will only contain changes since the last backup e.g. files B000501.jpg, B000502.jpg etc
          If you ever have to do a complete restore you start with the TLY file from the latest incremental backup. The program automatically recognizes the number of incremental steps and you will be prompted to insert a disc or navigate to the appropriate drive.
          Incremental backup’s are obviously much quicker to write to disk but I recommend that you periodically perform another full backup and delete any earlier backups.
          • 2. Re: Can't make an incremental backup in PSE 10 Organizer
            Hi 99jon -
            Thanks for your speedy response! I /still/ can't get the incremental
            backup to work. However, since I back up about once per week, I've
            decided to just make /full/ backups instead. In my case, it only takes
            about 20-30 seconds anyway.
            Thanks again!
            Jeff
            • 3. Re: Can't make an incremental backup in PSE 10 Organizer
              kellisails
              I am trying to make my first incremental on my PSE 10 catalog too! I am very familiar with the process as I have been cataloging files for many years.
              I have about 50,000 photos tagged and organized.
              Of course my initial full backup takes some time, I get it going and then go to bed. By morning it is done. Well, I just made a fresh full backup because my first try at an incremental wouldn't go, I thought maybe it was because I had moved my backup to a different external drive, though I gave it a valid path to the backup.tly file (via browsing to it). So here I am trying again with a new full backup on the same drive it originated on.... still, twice, it has completely stalled out my program, and Elements quits responding. Windows ends up telling me to close the program.
              Well, this isn't any fun because each step in the starting up of a backup takes a pretty long time as it calculates the final size and then grinds away for about 10 - 15 minutes before Windows tells me it's not responding. In my experience it usually does take a long time for the .tly to get loaded up and for the incremental to start, but it goes much quicker then to get the incremental done.
              I'm not sure what to do.
              My catalog takes a LONG time to back up - not just a few seconds.
              Kelli
