Hello,
Is there a way to lock the 'current date' field after it was saved the first time??
At the moment the field updates every time the form is opened.
I am using this (from the custom object library):
form1.#subform[0].CurrentDate::ready:layout - (FormCalc, client)
// Current Date in short-style date format.
$.rawValue
Thank you
Simon
What is should read is this
$.rawValue EQUALS num2date(date(), DateFmt(1))
Total Likes
wrap you code into an if expression at the initialize event.
The date then will only be populated, if the field is empty.
if ($.isNull) then
$ = Num2Date(date(), DateFmt(1))
endif
Worked like a charm. thanks so much!
Total Likes
I need to use this same code, and it is working like I need. The problem I am having is that now when I use the Submit button, I am getting a "Date validation failed" error message. I don't have any validation on this field, so any thoughts as to where it is coming from? I do have this code to validate other fields, which all work with no errors:
if (form1.Tailboard.Supervisor.rawValue == null)
xfa.host.messageBox("Choose a supervisor from the list.", "", 0);
xfa.host.setFocus("form1.Tailboard.Supervisor");
if (form1.Tailboard.Header.Table1.Row1.PersonInCharge.rawValue == null)
xfa.host.messageBox("Enter the name of the Person in Charge.", "", 0);
xfa.host.setFocus("form1.Tailboard.Header.Table1.Row1.PersonInCharge");
if (form1.Tailboard.Header.Table1.Row1.WorkLocation.rawValue == null)
xfa.host.messageBox("Enter a Work Location/Structure Number.", "", 0);
xfa.host.setFocus("form1.Tailboard.Header.Table1.Row1.WorkLocation");
if (form1.Tailboard.Review.Review1.Review1.rawValue == null)
xfa.host.messageBox("Check 'YES' that you have completed task 1.", "", 0);
xfa.host.setFocus("form1.Tailboard.Review.Review1.Review1");
if (form1.Tailboard.Review.Review2.Review2.rawValue == null)
xfa.host.messageBox("Check 'YES' that you have completed task 2.", "", 0);
xfa.host.setFocus("form1.Tailboard.Review.Review2.Review2");
if (form1.Tailboard.Review.Review3.Review3.rawValue == null)
xfa.host.messageBox("Check 'YES' that you have completed task 3.", "", 0);
xfa.host.setFocus("form1.Tailboard.Review.Review3.Review3");
if (form1.Tailboard.Review.Review4.Review4.rawValue == null)
xfa.host.messageBox("Check 'YES' that you have completed task 4.", "", 0);
xfa.host.setFocus("form1.Tailboard.Review.Review4.Review4");
if (form1.Tailboard.Review.Review5.Review5.rawValue == null)
xfa.host.messageBox("Check 'YES' that you have completed task 5.", "", 0);
xfa.host.setFocus("form1.Tailboard.Review.Review5.Review5");
else if (form1.Tailboard.Supervisor.rawValue != null &&
form1.Tailboard.Header.Table1.Row1.PersonInCharge.rawValue &&
form1.Tailboard.Header.Table1.Row1.WorkLocation.rawValue &&
form1.Tailboard.Review.Review1.Review1.rawValue &&
form1.Tailboard.Review.Review2.Review2.rawValue &&
form1.Tailboard.Review.Review3.Review3.rawValue &&
form1.Tailboard.Review.Review4.Review4.rawValue &&
form1.Tailboard.Review.Review5.Review5.rawValue != null){
RealEmail.event__click.submit.target = "mailto:" + form1.Tailboard.Supervisor.rawValue + "?subject=" + "SJO" + " — "
+ form1.Tailboard.Supervisor.formattedValue + " — "
+ form1.Tailboard.Header.Table1.Row1.Date.rawValue;
RealEmail.execEvent("click");
Total Likes
