I have been scripting a simple database connection to check login credentials and am comming accross these errors:
Channel.Call.Failed
NetConnection.Call.Failed:
HTTP: Status 500
Any PHP code I run that is not connecting to MYSQL runs fine. But if I try to connect to the database thats what I get.
Here is my mxml:
<s:RemoteObject id="LogInService"
source="Novus.NovusUser.getLogIn"
destination="AMFPHP"
fault="faultHandler(event)"
showBusyCursor="true">
<s:method name="getLogIn" result="onResult(event)" fault="faultHandler(event)"/>
</s:RemoteObject>
Which calls this actionscript:
private function btn(event:Event):void
switch(event.target.id)
case "LogInSubmit":
LogInService.getLogIn(UserName.text, PW.text)
break;
private function onResult(result:ResultEvent):void
Alert.show("Result " + result.token.result);
if(result.token.result == true)
currentState = "Main";
else
Alert.show(String(result.token.result));
private function faultHandler(fault:FaultEvent):void
CursorManager.removeBusyCursor();
var errorMessage:String = "code:\n" + fault.fault.faultCode + "\n\nMessage:\n" + fault.fault.faultString + "\n\nDetail:\n" + fault.fault.faultDetail;
Alert.show(errorMessage);
and calls this PHP:
If I comment out the database connection it returns a false value to me just fine but with it there it throws an error
<?php
class GetLogIn
private $_db;
public function getLogIn($U, $P)
//Connect To Database
$hostname='127.0.0.1';
$username='root';
$password='*********'; //not realy ***** blocked it out
$dbname='mydatabase';
try
mysql_connect($hostname,$username, $password) OR DIE ('Unable to connect to database! Please try again later.');
mysql_select_db($dbname);
$sql = "Select * FROM empusr WHERE UserName = '$U' and Password = '$P'";
mysql_close();
if ($sql)
return true;
else
return false;
catch
return 'Unable to connect to database! Please try again later.';
I have a crossdomain.xml but I am unsure if I have it placed right.
I also have a services.conf but am unsure if that also needs to be altered to adjust for MySQL.
Any help would be appreciated.
Found the problum
The connection string had to be placed in the public _constructor function of the class.
<?php
class EmployeeService
public function __construct()
$username='root';
$dbname='myDatabase';
mysql_connect($hostname,$username, $password);
public function logIn($N, $P)
$query = "SELECT * FROM EmpUsr WHERE UserName = '$N' AND Password = '$P'";
$result = mysql_query($query);
if ($result)
return true;
else
return false;
