I'm on RH8. I have a broken link which I can't seem to get rid of. When I try to import the htm, RH gives me a message that the topic is already in the project file. Is there a way to fix this? Or do I have to do something weird like remove the topic from the project and then reimport it to get rid of the broken link?
The bottom line is that you can't have two files of the same name in a project unless they are in different folders. So you could import the file into a different folder or remove the other file. Only you can tell which action is better.
thank you, Colum, that answers my question.
