If I do a Dip to White between segments, everything works as it should. But if I add a graphic to "Video 2", and also add the Dip to White with it (at the same point as the video 1 transition), as it fades from white back to video, the graphic is shifted a pixel or two. Once it's totally disolved out of white, it snaps back to it's correct position. Very annoying.
I searched the forums, and found one other person with the same problem, but it was never addressed.
Any help would be appreciated.
I can't tell you why it's happening, but you can probably get around it by nesting.
