I'm putting together a slide show DVD. There are a total of 7 slide shows containing 480 pictures. All pictures are jpg's about 1000X1600 pixels and 500KB-700KB each. I have 3 menus for navigation. Not all of the chapter menu buttons point to a "slide show", some of them point to a picture inside certain slide shows according to my client's requests. (example, slide show 1 contains 70 pictures. Chapter 1 points to "slide show 1" Chapter 2 points to "slide show 1 photo 50"). All slide shows are linked so that when the first slide show is over, it will automatically "end action" to the next slide show etc... All my settings are typical. NTSC 4:3 SD 720X480 progressive.
There are NO video files in my DVD at all. No timelines at all. No audio at all.
The Symptoms/problem that I'm getting is this, when I try to Preview my DVD and ALSO when I try to build my DVD, the build will go through and "build the slide shows" then after it does that, this will come up
I've read some of the previous posts (one of them is in French for cryin out loud. Had to use Bing translator and it sounds all weird). What I can gather is this,
Re: internal software error: .\Vobulator\BlockPlanner\BlockPlanner.cpp, line 217
I found out it was due to selecting an image file as the video layer
in a menu, causes the error everytime. I just paste the image in with
'edit in photoshop' instead now. But thanks."
Another person said just about the same thing... The only problem is, I have no idea what this means. I don't know what it means to "select an image file as the video layer in a menu..."
Hardware/software is as follows:
custom build:
i5 processor (4 core) 2.6ghz
8 GB RAM 1333MHz
300GB C: drive (2X150 GB 10K RPM Raptors)
1.2TB D: drive (2X7,200 RPM 640GB WD's)
Burner is LG Super multi
secondary burner is Sony Commercial Blu-Ray burner
Video card is Saphire Build (Radeon 5450 PCI-E 16X)
Windows 7 X64 Pro
All Adobe is CS5 Production package.
If I'm leaving anything out, please let me know.
HELP! and Thanks. I'd really love to fix this without rebuilding the whole DVD. Take long time.
TEX
