4 Replies Latest reply on Mar 9, 2012 4:51 AM by SunHawkProductions
    Out of Sync when importing rendered sequence
      This is the first time I've had this happen and haven't been able to solve the problem yet and haven't found any solutions yet through searching. Using CS5.5, I'm building a show consisting of 7 or 8 already rendered sequences. All seem fine when put together, but one sequence is thrown way out of sync when I import it. The file plays fine otherwise and it isn't until it's imported into premiere that the problem occurs. I've tried re-rendering several times and get the same out of sync problems. And it eventually gets wildly out of sync, not just a few seconds. The properties of the clip are:
      Type: MPEG Movie
      File Size: 1.5 GB
      Image Size: 1920 x 820
      Frame Rate: 23.976
      Source Audio Format: 48000 Hz - compressed - Stereo
      Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
      Total Duration: 00:04:23:09
      Average Data Rate: 6.0 MB / second
      Pixel Aspect Ratio: 1.0
      This is the same as all the other rendered/imported sequences. I'm at a loss here. Is there anyone who can help steer me to solving this?
