I get the following error when using the 64 bit installer and unistaller on my windows 7 64bit:
"Invalid argument or invalid use of argument: %TEMP%/1234.dir/installflashpalyer.exe"
where %TEMP% is my windows temp directory and 1234.dir changes every time.
As a result of this error, the 32bit version of Flash neither installs nor uninstalls. This happens with both the ActiveX and the plugin versions. Installing the 32 bit version separately works just fine. It has been happening ever since the 64 bit version was released.
Any Ideas?
What are your files in folders C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash?
What are the contents of the FlashInstall file in both folders?
What are your browsers?
From where did you download these installers / uninstallers?
I used the instructions and download links at http://forums.adobe.com/message/4041846#4041846.
I am using IE and Firefox for Browsers. The FlashInstall.log files seem to be indentical.
My C:\Windows\System32\Macromed\Flash contents:
Flash64_11_1_102.ocx
FlashInstall.log
FlashUtil64_11_1_102_ActiveX.dll
FlashUtil64_11_1_102_ActiveX.exe
FlashUtil64_11_1_102_Plugin.exe
NPSWF64_11_1_102.dll
FlashInstall.log:
=O====== M/11.1.102.62 2012-02-23+20-08-24.911 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\d50c.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\d50c.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-02-23+20-08-34.837 ========
=O====== M/11.1.102.62 2012-02-23+20-08-50.468 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\3988.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\3988.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-02-23+20-08-56.249 ========
=O====== M/11.1.102.62 2012-02-23+20-09-02.598 ========
0000 00000010 "C:\Users\jpapadop\Downloads\install_flash_player_11_active_x_32bit.exe"
0001
0002
0003
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash11f.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11f_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11f_ActiveX.dll
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/11.1.102.62 2012-02-23+20-09-09.306 ========
=O====== M/11.1.102.62 2012-02-23+20-09-12.379 ========
0000 00000010 "C:\Users\jpapadop\Downloads\install_flash_player_11_plugin_32bit.exe"
0001
0002
0003
0004
0006
0007
0008
0009
0010
0011
0012
0013
0014 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32.dll
0015 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11f_Plugin.exe
0016 00000017 C:\Windows\SysWOW64\Macromed\Flash
0017 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0018
=X====== M/11.1.102.62 2012-02-23+20-09-18.260 ========
=O====== M/11.1.102.62 2012-02-23+20-32-39.479 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\4c3.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\4c3.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-02-23+20-34-19.246 ========
=O====== M/11.1.102.62 2012-02-23+20-38-44.777 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\97af.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\97af.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-02-23+20-39-17.653 ========
and my C:\Windows\SysWOW64\Macromed\Flash contenrs:
Flash11f.ocx
FlashInstall.log
flashplayer.xpt
NPSWF32.dll
FlashInstall.log:
0001
0001
0001
0002
0003
0004
0006
0001
0002
0003
0004
0006
0007
0008
0009
0010
0011
0012
0013
0018
0001
0001
Thanks for the log. Could you try cleaning out your temp folder, restarting the system then trying again?
Chris
I've talked with our installer group and none of us have seen this error before. What version of Windows are you using (Home, Premium, etc) and what locale are you in (US or somewhere else)?
Chris
I am using Windows 7 Ultimate 64-bit and I am in the U.S.
I tried clearing out the temp folder, that did not help. The direcroty under the temp folder that is in the error message actually is the one the installer creates every time, I am assuming in order to install the 32bit software. From what I was able to figure out, the reason it errors out is because it tries to launch itself as a parameter. Here is a snippet from process explorer with the error superimposed: This is where it errors out and the 64-bit is installed but no 32-bit.
Actually both the 64-bit installer and uninstaller exhibit the same behaviour.
NiteOwl,
Would you re-post the contents of the installation log file in System32 please?
C:\Windows\System32\Macromed\Flash\FlashInstall.log
John
=O====== M/11.1.102.62 2012-03-02+13-18-12.090 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\56d8.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\56d8.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-03-02+13-18-13.788 ========
=O====== M/11.1.102.62 2012-03-02+13-18-22.800 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\80d4.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\80d4.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-03-02+13-18-24.829 ========
NiteOwl,
It appears that you are still posting the logfile C:\Windows\SysWOW64\Macromed\Flash\FlashInstall.log. I can tell because of the "-install -skipARPEntry -iv 1" arguments. These arguments are only sent to the 32-bit installer.
I would like to see your installation log file for the 64-bit installation. This is the location (notice that the 64-bit log file lives in System32, not SysWOW64).
John
That is my FlashInstall.log from my system32 directory. As I mentioned before, both of those logs in my System32 and SysWOW64 look identical.
John,
Just to clarify, here is what I did this morning:
I ran the uninstaller (uninstall_flash_player_64bit.exe, which gave me the error just like above). I then cleaned all my temp and Macromed Directories and rebooted my machine.
I then used the 64bit installers of both the ActiveXand the plugin versions of Flash11. Both times a got an error similar to the wbove (The temp directory changes). Inow have identical FlashInstall.log files in both my System32 and SysWOW64 Macromed/Flash directories containing the following:
=O====== M/11.1.102.62 2012-03-05+14-47-01.138 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\9c5f.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\9c5f.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-03-05+14-47-03.941 ========
=O====== M/11.1.102.62 2012-03-05+14-47-20.183 ========
0000 00000010 "C:\users\jpapadop\temp\tmp\e754.dir\INSTAL~1.EXE" "c:\users\jpapadop\temp\tmp\e754.dir\installflashplayer.exe" -install -skipARPEntry -iv 1
0001
=X====== M/11.1.102.62 2012-03-05+14-47-21.943 ========
The System32/Macromed/Flash directory also contains:
and Flash works in my 64bit IE works but not in my 32bit IE nor in Firefox 10.
Let me know if you need more info and thanks for your help.
Have you tried this?
Download these files to your desktop:
Flash Player for Internet Explorer
Flash Player for other browsers
Download this uninstaller:
Windows 64-bit: http://download.macromedia.com/pub/flashplayer/current/uninstall_flash _player_64bit.exe
Exit all browsers and disconnect from the Internet.
Run the uninstaller.
Reboot.
Delete the Flash folder in folders C:\Windows\System32\Macromed and C:\Windows\SysWOW64\Macromed.
Delete the Flash Player folder in folders %appdata%\Adobe and %appdata%\Macromedia.
Run the installers.
Did that, same result as my post above. Had to use the 32bit installers separately to use Flash in Firefox.
Have you guys come up with anything else on this?
Hi NiteOwl,
We're working on it. I will let you know when we have a fix available.
John
I downloaded the new uninstaller and installers (version 11.2.202.228) and they all work perfectly now.
Thanks for your help.
The 64-bit installer will install both 32-bit & 64-bit Flash Players.
Have you tried the latest Flash Player 11.2. 202.228 ?
