11 Replies Latest reply on Mar 21, 2012 4:16 AM by suren_tringer
    Issue with find out the pageItem type
    suren_tringer Newcomer
      Hi all,
      i am trying to find out the all pageitem's type and its data on a document .i just use the following code to find out the pageitem's type .
      InterfacePtr<ISpreadList> spreadList(document, UseDefaultIID());
              ASSERT(spreadList);
              if(!spreadList) {
                  break;
              UIDList frameList(database);
              int32 spreadCount = spreadList->GetSpreadCount();
              for (int32 spreadIndex = 0; spreadIndex < spreadCount; spreadIndex++ )
                  UIDRef spreadUIDRef(database, spreadList->GetNthSpreadUID(spreadIndex));
                  InterfacePtr<ISpread> spread(spreadUIDRef, UseDefaultIID());
                  ASSERT(spread);
                  if(!spread) {
                      break;
                  int32 numberOfPages = spread->GetNumPages();
                  for (int32 nPage = 0; nPage < numberOfPages; nPage++ )
                      UIDList pageItemList(database);
                      spread->GetItemsOnPage
                       nPage,
                       &pageItemList,
                       kFalse,
                       kFalse
                      bool16 hasContent;
                      int32 pageItemListLength = pageItemList.Length();
                      for (int32 j = 0; j < pageItemListLength; j++ )
                          UIDRef pageItemRef = pageItemList.GetRef(j);
                          InterfacePtr<IGraphicFrameData> graphicFrameData(pageItemRef, UseDefaultIID());
                          hasContent =graphicFrameData->HasContent();
                          InterfacePtr<IPathGeometry> pathGeometry(pageItemRef,UseDefaultIID());
                          if (pathGeometry != nil)
                             PMPageItemType pathType = Utils<IPathUtils>()->WhichKindOfPageItem(pathGeometry); //issue is this statement simply break up the execution
                              switch (pathType)
      please can any one help me?
        • 1. Re: Issue with find out the pageItem type
          markus freitag Champion
          did you try it with IPageItemTypeUtils instead of IPathUtils?
          Markus
          1 person found this helpful
          • 2. Re: Issue with find out the pageItem type
            Hi Markus , thanks for your reply ,
            i had tried with IPageItemTypeUtils also , still i get same issue .is there anything wrong that the way of getting pageitem's UIDRef
            • 4. Re: Issue with find out the pageItem type
              Norio Kawamura Champion
              You need to check the class of UIDRef.
              Is the class kGroupItemBoss, kSplineItemBoss or others?
              • 5. Re: Issue with find out the pageItem type
                Hi
                thanks for your reply(Norio,Markus)
                as i follow your suggestion i am able to get all the page item and its type using its uidref .now i want to get the frame of that page item.
                can you tell me how do i get the frame of a pageitem(i have page item's uidref) ?
                thanks
                Message was edited by: suren_tringer
                • 6. Re: Issue with find out the pageItem type
                  Pickory Pioneer
                  This might help.
                    InterfacePtr<IGraphicFrameData> graphicFrameData(content, UseDefaultIID());
                  InterfacePtr<IGeometry> frameGeom(graphicFrameData, UseDefaultIID());
                  PMMatrix inner2parent = ::InnerToPasteboardMatrix(frameGeom);
                  PMRect r = frameGeom->GetStrokeBoundingBox(inner2parent);
                  • 7. Re: Issue with find out the pageItem type
                    Hi Pickory ,
                    Thanks for your reply ,
                    Content = ? (is pageitem's uidref)
                    • 8. Re: Issue with find out the pageItem type
                      Pickory Pioneer
                      Indeed.
                                                              IDataBase* db = ::GetDataBase(doc);
                                                              UIDRef content( db, uid2Test);
                      • 9. Re: Issue with find out the pageItem type
                        Hi Pickory
                        i have tried the following code ,but it doesnt works
        nPage,
        &pageItemList,
        kFalse,
        kFalse
                                          bool16 hasContent;
        UIDRef content = pageItemList.GetRef(j);
                        any thing need to be included?
                        • 10. Re: Issue with find out the pageItem type
                          Pickory Pioneer
                          Have a look in  BscMEInvertFacade.cpp
                          • 11. Re: Issue with find out the pageItem type
                            Hi all
                            i am able to get page item's frame but it something un releated to original frame.(i am not sure whether i need to tranform it to get page item's frame corresponding to the page area)
                            please help me !
