1. Re: Convert original image to sharp Line art?
Noel Carboni Mar 8, 2012 11:45 PM (in response to manojb05)Beyond simple functions that produce only limited results, like the Filter - Stylize - Find Edges function, I don't think what you want is a trivial request.
I have heard of "auto tracing" features in other programs or in 3rd party plug-ins, but I've not personally seen anything that will just give you results much beyond what Find Edges and a little Curves manipulation can do.
-Noel
2. Re: Convert original image to sharp Line art?
manojb05 Mar 8, 2012 11:52 PM (in response to Noel Carboni) -
3. Re: Convert original image to sharp Line art?
markerline Mar 8, 2012 11:53 PM (in response to Noel Carboni)I was also going to recommend Find Edges but when I did it I think I must have used a low res image of what was posted above and I got a lot of pixelation.
As far as other programs are concerned I would consider Adobe Illustrator's Live Trace options although the word is that Live Trace does not replace Manual Tracing which is painstakingly long for a complex image such as this one. But you do get crisp vector results. I don't know what you can do in Fireworks. Adobe Flash also has a vectorization option but I'm not sure you'll get black-and-white art.
4. Re: Convert original image to sharp Line art?
manojb05 Mar 9, 2012 12:01 AM (in response to manojb05)thanks markerline & c.pfaffenbichler i am making brochure that brochure we used a line art image for a particular dance in different state, client send a highres JPG file. but i am try that in photoshop but i dont get good result as similar to noel post, if anybody know how can i convert to sharp line art
5. Re: Convert original image to sharp Line art?
c.pfaffenbichler Mar 9, 2012 12:04 AM (in response to manojb05)if any chance we can convert the image in same quality please help this
Personally I currently see no realistic option for achieving such a result automatically.
I would recommend Illustrator – Object > Live Trace may provide a starting point, but I guess a lot of manual improvements/tracing may be necessary.
6. Re: Convert original image to sharp Line art?
Mylenium Mar 9, 2012 12:08 AM (in response to manojb05)As the others already said - no chance of doing this in PS. It needs to be traced in Illustrator.
Mylenium
7. Re: Convert original image to sharp Line art?
PECourtejoie Mar 9, 2012 2:57 AM (in response to manojb05)You need to simplify the image before you try to find its edges, or trace it. I would convert the background to a layer, smart object it, and run a blur filter to remove details, then run the edge finding, or tracing it.
8. Re: Convert original image to sharp Line art?
JamesNRoberts Jan 31, 2013 8:09 AM (in response to manojb05)As others have said I dont think you will be able to convert the image you have posted to look like the result you want from the other image you posted, the detail in the original is just to high. I use the method described below for doing my line art in Photoshop and it works well but you seem to want to reduce your image to a much simplier representation. I have used this site before, it used to be free but now I think you only get a couple of free credits when you join, convert a photo to line drawing, quite simple to use and you can select to remove noise which might reduce the complexity of the original image.
In Photoshop try:
Duplicate original layer
Change top layer color mode to color dodge
Invert top layer
Apply Gaussian blur (choose low pixel radius for less detail so reducing image complexity)
Add adjustment layer and set saturation to be -100
Retouch anywhere with brush tool to complete
