Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Display pattern issue..
Avatar
Level 10
I need to have a display pattern on a Numeric field so that when an user enters 12 as it's value,
the display should be as 12.00%
Tried various options but nothing turned up correctly.
Any advice is greatly appreciated.
Nith
1 Accepted Solution
Avatar
Correct answer by
Level 10
Avatar
Correct answer by
Level 10
I always use
Avatar
Level 10
Excellent radzmar!
Do you have any article/documentation which explains these patterns?
Many thanks,
Nith
Avatar
Level 10
detailed information about the picture clauses can be found in the XFA spec.
As the percentage picture clause works different than expected, I use the workaround with the quotation marks in the pattern.
http://partners.adobe.com/public/developer/en/xml/xfa_spec_3_3.pdf
Page 1180 > Effect of the % Picture Symbol
