trying to install flash 11... says close firefox...... firefox is closed.....stops at 50 % complete
If you are using Windows, do the following:
- Press Ctrl+Alt+Del
- Select Task Manager
- In the Processes tab, locate Firefox.exe
- Select Firefox.exe
- Click End process.
For more information on Flash player installation, see http://kb2.adobe.com/cps/191/tn_19166.html#main_Ensure_that_the_Flash_Player_plug-in_is_enabled
Hey Preran , Thank you for the quick reply..Yes I did that...As I said in the original post..I made sure Firefox was not running... I had stored the install in my documents...Checked task manager no processes running attemped to install again , same thing..
Download the full installer from http://forums.adobe.com/thread/909550 and save it to disk.
Close all browser windows and run the downloaded installer.
If you still need help, please specify your operating system & version & edition.
[Topic moved to Flash Player forum]
Hey Pat , thanks for the quick response.... I will try that..
