1. Re: Panasonic GX1, raw-file to dng
MadManChan2000Mar 2, 2012 6:43 PM (in response to LarssonHugo)
Is it really hung, or does it appear to be stuck on the last image? If you move the cursor when it's on the last image, does it finish?
If you uncheck the "Fast Load Data" option, are the resulting DNG images readable in the other software?
Eric
2. Re: Panasonic GX1, raw-file to dng
LarssonHugo Mar 5, 2012 10:25 AM (in response to MadManChan2000)Thanks for answering.
Moving the cursor doesn't complete the process unfortunately.
As for the "Fast load data" option, seems it's missing from my version of DNG Converter (6.6.0.261)
I've tried the different versions for compability, also linear and uncompressed.
3. Re: Panasonic GX1, raw-file to dng
MadManChan2000Mar 5, 2012 12:01 PM (in response to LarssonHugo)
Which compatibility versions did you try? For example, 4.6?
Eric
4. Re: Panasonic GX1, raw-file to dng
LarssonHugo Mar 10, 2012 10:34 AM (in response to MadManChan2000)I've tried 2.4, 4.1, 4.6, and 5.4.
Custom settings didn't work either. Linear on or off.
5. Re: Panasonic GX1, raw-file to dng
MadManChan2000Mar 10, 2012 11:06 AM (in response to LarssonHugo)
It is possible that the OS simply doesn't support this camera model yet.
6. Re: Panasonic GX1, raw-file to dng
LarssonHugo Mar 10, 2012 1:16 PM (in response to MadManChan2000)I'm sorry, I may be confused to how the DNG-converter works.
I thought I could take a raw-file, which is supported by DNG-converter, and create a DNG-file which is readable by the os or any program that handles DNG.
Does the os still have to support the raw-file from the camera to read the finished DNG-file?
7. Re: Panasonic GX1, raw-file to dng
MadManChan2000Mar 10, 2012 2:59 PM (in response to LarssonHugo)
You understood correctly about how the DNG conversion works.
However, not all software reads all DNG.
For example, sometimes a software still internally checks whether it supports a given camera model and may refuse to process unrecognized models.
I will do some of my own testing later with these images and let you know what I find.
Eric
8. Re: Panasonic GX1, raw-file to dng
LarssonHugo Mar 11, 2012 1:55 PM (in response to MadManChan2000)Thank you very much for your help and time with this issue.
Appreciate it!
Found a rc of DNG Converter 6.7.0.319 beta, still no luck.
So I tried an old Nikon D80 raw file, Camera Raw 6.6 compability, which worked just fine.
