4 Replies Latest reply on Mar 13, 2012 6:27 AM by casper_no
    Remove userStyle entry without ApplyElementUserStyleOperation?
    casper_no Newcomer
      ApplyElementUserStyleOperation is deprecated with TLF 2.0. But I can't find a way to remove a userStyle without it. If I try to use ApplyFormatToElement with a TextLayoutFormat, it won't clear userStyles set to "undefined", just as it won't clear other styles.
      Any suggestions? My code is working now using ApplyElementUserStyleOperation, but it always feels wrong to use deprecated methods.
        • 1. Re: Remove userStyle entry without ApplyElementUserStyleOperation?
          Jin-Huang Champion
          Use “delete” to undefine a property
          if (val === undefined) delete _styles[val];
          • 2. Re: Remove userStyle entry without ApplyElementUserStyleOperation?
            casper_no Newcomer
            Good point, I've tried that and it works. But in this case I need to keep the undo-stack intact, and manipulating properties directly reset it. Is there any way of clearing user styles through the EditManager?
            • 3. Re: Remove userStyle entry without ApplyElementUserStyleOperation?
              Jin-Huang Champion
              ClearFormatOnElementOperation or ClearFormatOperation
              • 4. Re: Remove userStyle entry without ApplyElementUserStyleOperation?
                casper_no Newcomer
                No, that doesn't work. Or at least, ClearFormatOnElementOperation doesn't work for clearing userStyles.
                The below method in ClearFormatOnElementOperation does the job. The problem is that TextLayoutFormat.description object which it iterates on does not contain userStyles as far as I can see.
                public override function doOperation():Boolean
                                              var targetElement:FlowElement = getTargetElement();
                                              adjustForDoOperation(targetElement);
                                              _undoStyles = new TextLayoutFormat(targetElement.format);
                                              if (_format)
                                                        var newFormat:TextLayoutFormat = new TextLayoutFormat(targetElement.format);
                  // this is fairly rare so this operation is not optimizied
                                                        for (var prop:String in TextLayoutFormat.description)
        if (_format[prop] !== undefined)
        newFormat[prop] = undefined;
                                                        targetElement.format = newFormat;
                  return true;
